'03 F150 Lift
'03 F150 Lift
What's up guys.
I just found this site today while looking at different pictures of lift kits. I plan on getting a 6" suspension, not sure what brand yet, and I plan on running 35's..
Few questions..
The shop I was at getting prices showed me a Rough Country 4-5" lift that was about $1500 installed, compared to almost $3000 installed for a Fabtech, Pro Comp, etc. On Rough Country's site, they say that the lift will clear 35's, and I am assuming that no trimming will be involved. I'm not sure what tire/ wheel combo I will run. I just started looking at lifts and oversized tires so I'm pretty much a noob! Any thoughts you guys have will be appreciated. Tell me what you think!
Thanks,
Andy
Few questions..
Thanks,
Andy
the Fabtech, RCD, and BDS are the best kits for the 97-03 F150 4x4's
but for road use/ light off road use you can get away with a Rancho or RCX.
The 4" rancho will clear 35's on a 10" wide wheel with 4.5" of backspacing. You MIGHT have to trim slightly. Id honestly look at the RCX they sell them on Ebay for about 900.
If you plan to offroad id really suggest the higher 3.
The gearing is up to you, 3:73's and 35's isnt bad. Do you ever plan on going bigger?
4.56 gears would get you back up to a stock ratio
After the 35's wear, i would probly do a body lift and get 37's. I would definitely re gear going bigger than 35.
its hard for a company to do anything for the rear axle, theres SOOO many factors that make the length of the rear driveshaft its too hard to offer a spacer.
Minimonster17 had his extended i know of.
EDIT: oops i meant with a 4-5" lift you SHOULDNT need to extend the drive shafts
They will work with the 35's.
Or you could just do the 35's now and save for the re-gear and do that when you get the money.
The
3:73's work ok with the 35s but a re gear is much better performance and mpg wise.
Just wanted to make sure NOOB there knew what you were talking about.
