Leveling Kit
My guess is around $200. Have you thought about putting it in yourself it is very very easy to do and does not take to much time. It only took me about 2 hours to do. Just make sure that you get your front end re-aligned when your done.
Here is a link to the DIY thread:
https://www.f150online.com/forums/su...t-install.html
So if I install it myself there will be no reason for me to rent a spring compressor? How much does it cost to have a car re-aligned. I have a shop that my company built the building for and he said he would do the whole job including realign for $150. Is this a good deal or should i still attempt it myself?
Below is the link to a picture of the leveling kit.
I wanted yal to see a picture so you will know more about it.
http://www.suspensionconnection.com/...con/22905.html
What 05supercrew said,
I just did the Bilstein strut kit and love it! Makes more sense to get that if your already going through the trouble of taking apart the spring assembly! Although it does cost a bit more than a spacer does...
check out this site ----> http://store.topguncustomz.com/store...82&i=193574766
I'm assuming you have a 4x4... but if you don't there is a 4x2 kit also available at the bottem of the page!
good luck
Nem
good luck
Nem
