My alignment is good yet my tires still wear funny
Anybody know going on here? 2001 F150 4x4 supercrew with a 6" Fabtech on 285/17R17 BFG A/Ts. I took it to an alignment shop and for the most part it's all pretty good. They said the left wheel hub bearing had a tiny bit of play, and so did the idler arm, but would that make the tires wear as bad as they are (the inside/middle is bald, the outer still has a decent amount of tread). They said the camber (which would usually cause this sort of wear) was off barely, but it was so close, they'd have to guesstimate to get it perfect, and that it probably wasn't the cause of the wear. They really weren't sure why it's wearing so bad. Here are the numbers they gave me:
Somebody mentioned my sway bar endlinks, but I've got the Fabtech end links from the lift that are still in good condition. I'm already going to replace the idler arm because it's squeaking. I'd rather not have to replace the left bearing as that's a very expensive part replacing the whole hub . So anybody have a clue as to what's up?
well the tires haven't ever been over inflated. I checked the tire pressure a few weeks ago and the rear tires were a little low, but nothing extreme. The wheels are stock wheels, and the BFGs are pretty standard tires, so I'm really at a loss of why these tires are the way they are.
Dude, If they said those numbers were normal then its time to change shops
You have to much negative camber on the front left wheel
Your right wheel is just in specs ( barley) BUT should be less than -0.5 on negative camber
You do not have enough positive caster on EITHER wheel
And you have TO MUCH negative toe in on both wheels
From what i see on you image, that shop did not know what they were doing because nothing is in specs at all and you caster is miles out.
I would not be surprised if the back of your truck wags left to right when you change lanes going down the road.
You need to go to a better shop before you ruin your tires.
Cool, when you take it in, take your numbers that you posted up and tell them you want your alignment as close to the normal numbers as possible, also tell them you want a print out sheet on the final numbers.
What i am talking about when i say normal numbers is: On your image it shows Min, Normal, Max
The min. and Max. is the factory specs adjustable range, You cannot be outside those numbers in either direction. If your to high or to low in the adjustable range it will lead to abnormal tire wear
The Normal is what the factory has it set to and what the dealership will set it to if you went to them for a alignment.
I just remebered~ Its your stock wheels causing this. The backspacin/offset is not within Fabtech's specs. They even say that the stock wheels are not usable.
I thought of this right after you picked up those parts from me!
no a wheel cannot throw off caster, camber or toe...however i did notice you have a 2" spacer listed in your sig. that may be keeping them from being able to dial it in if the adjustment on caster/camber is maxed out.
its not the wheel persay its the lift. I have a buddy with the exact same problem. just on a chevy
The lift requires wheels with a certain backspacing/offset and if this is not met than it will throw the alignment off!
Sometimes you can even get an alignment printout to show little to no problems but thats because the alignment is maxed out one way or the other.
I looked at cashel's front suspension and nothing is loose of done wrong!
The alignment is obviously off looking at the chart but i highly doubt they will be able to correct it enough with the stock wheels still on it
yes but a wheel with improper backspacing will only throw off the scrub radius and SAI (which noone really cares about anyways..) . im pretty sure the only reason lift manufactures recomend certain backspacing is for clearance issues with steering knuckles or the new tie rod locations on the steering knuckles.
