What part is this?
What part is this?
I have a 2003 explorer 54,000 miles--making a loud hum from 55mph and above almost a vibration--tires look good bt found this rubber piece that looks like its falling apart. What is it called? Still under extended warranty anything i should have checked out before it expires?
any help would be appreciated.
Stephanie
Stephanie
thats a tie-rod..how do i know..cause my freaking wife just got ina wreck in my truck and my poor baby (my truck) wasnt driveable for like days cause the tie rod was bent like a (c)..till i got the part..now shes in the body shop gettin all pretty again..get her back on friday.
that ball joint needs to be replaced. also, a bearing will cause a hum or howl so you could have the same problem as longjohnsilver's friend. it could be a bad tire as well if it is speed sensitive meaning that it makes a sound only at a certain speed and not at all times. ford should be able to diagnose it under warranty and it should be safe to drive just try to bring it in as soon as possible.
Ford says balljoints dont need replacing just because the boot is shredded-as long as there is no play they are good. However did get 3 new bearing assemblies & transmission shift solenoid. Do the balljoints need replacing if the boot is bad? I am worried about my warranty running out and then 2 or 3 months later they need replacing. Thanks
