Tire clearance on a leveling kit
Hey guys,
i am ready to install a leveling kit on my 05 fx4 supercrew and i dont know what to do. i need help with tires. i want to fill the gap but i dont want to rub. i was told 33's would be ok, but 35 would be better. i have a rancho quicklift 2.5" in mind. 33x12x17 on a 17x10. but like i said, i have conflicting comments coming left and right.....i dont know what to do. any ideas and comments would be great.
thanks
omar
thanks
omar
As a general rule, with a leveling kit on the new 4x4's, you can fit a 35x12.50 using the OEM wheels or 33's with aftermarket wheels. Also, there have been a few fitment issues with some aftermarket 17 inch wheels on the late production 2005 and newer trucks due to a change in brake calipers. I'd suggest going with an 18 inch wheel. I think the best looking combo on a leveled 4x4 is an 18x9 inch wheel with 5 to 6 inches of backspacing and a 325/60-18 (33x13.00) tire.
The tire sizes go by this ... The first number is the height of tire in inches. The second number is the tire width. The last number is always your wheel size. Metric tire sizes are a little bit different. A good tire chart can be found here ...
http://www.discounttire.com/dtcs/infoTireMath.dos
i appreciate your help....i didnt know there was a rule of thumb for these wheels....although, it did cross my mind at one point that stock rims would fit a bigger tire just because of the width...and aftermarket rims could only fit a smaller tire, again, because of the width.
again
thanks for your help
again
Why is that? Why can you put 35s on the OEM wheels, but can only go with 33s on aftermarket. Seems like it would be the other way around????
