shocks
Why do you say it's not the springs??? Cause it's not the shock either.
Okay so.....
Galaxy said > Shocks don't lift anything...they provide no weight support <
So please explain to me again how Bilstein 5100's can provide you with adjustable ride height of 0" to 2" ???
Based on great reviews, and assurances that they can, in fact, give you 2" of leveling, I had pretty much decided on them. But I'm still not sure how they work ???
Can somebody please explain this in a way that a mechanically 'declined' individual can understand it ?
Thank you,
Fish
Thank you,
Fish
Thank you,
Fish
Thank you,
Fish
Please do some searching as this subject gets beat to death about twice a month...but since we're here, I'll give you the quick and dirty version. Search for more detailed write ups by me.
On the '04-Present trucks they have what's called a coil over on the front. The shock and spring are together as one assembly with the spring mounted directly to the shock. The Bilstein 5100 for these trucks has different spring perches at different locations on teh shock body. Reinstalling the spring on one of these 'other than stock' spring perches preloads the coil spring. This preload on the spring, or the new mounting location, if you will, induces the lift...but do understand, the increased ride heigth is caused by the springs mounting location and NOT the shock absorber portion itself.
For the rear shocks and for the front shocks that are not coil overs...i.e. pre-'04 trucks, this is not the case.
Since you have no lift kit, Bilstein only makes one shock for your truck so not much to figure out there. Don't know what you're trying to accomplish with the springs but as far as options, you can go with a complete new spring pack, aal's, or air bags...or any combination of the three. If I was looking for GREATLY improved ride and capability, I'd check to see if Deaver or National Spring has a spring pack for a no-lift truck and then throw on some air bags.
