Bilstein 5100 shocks + leveling kit = even more lift??
'97 or '07???
What you speak of makes no sense what-so-ever if you have a '97...there is no "leveling kit" and there's no 5100 for a non-lifted truck..if in fact you have a '97.
If in fact you have an '07 then the answer is still no...sorta. You can use the shocks alone to gain the lift or you can use the shocks in the "no lift" configuration with the leveling kit, but there's not much use in doing that...financially or for lift purposes.
'97 or '07???
First of all, don't buy a set of aftermarket torsion bar adjustment keys. These things are a ripoff. They just allow you to put way too much preload on your torsion bars. This will lead to premature wear and tear on your ball joints and CV joints as well as destroy your ride uality. Just crank up the torsion bars enough to level your truck and get an alignment. This will allow you to easily fit 33 inch tires (285/75-16 (305/70-16 (285/70-17, 305/65-17, etc.).
