1.5" AS Leveling Kit
Old 12-07-2007, 04:09 PM
HuntinDawg's Avatar
Does anyone have this kit? Or has anyone heard anything about them? I want to clear 285/65/20 BFG All Terrains on the factory 20" wheels. I want just enough lift to clear the tires with no rubbing, but i do not want the front of the truck to sit higher than the back. The reason I want to know about this kit is because I have seen some F-150's with the 2" kit and the nose is still in the air.
Old 12-07-2007, 04:30 PM
nooq's Avatar
the 1.5" as should put you right where you want it to clear those tires.
Old 12-07-2007, 04:34 PM
05supercrew's Avatar
I have a 2''AS and im not even close to leveled.
Old 12-07-2007, 04:47 PM
tardman91's Avatar
You can clear those tire without a leveling kit.
Old 12-07-2007, 04:52 PM
Ronix's Avatar
[QUOTE=05supercrew]I have a 2''AS and im not even close to leveled.
QUOTE]
I did a 2" leveling kit and it looks damn level to me.
Old 12-07-2007, 05:03 PM
HuntinDawg's Avatar
I dont think I can fit those tires without a leveling kit....they are around 34.5" in diameter and around 11.50" wide. I will probably just go with the 2" to be safe....just looking at all of my options
Old 12-07-2007, 05:07 PM
K1NGoftheRanch's Avatar
i put the 2" on my supercrew and my back is if anything 1/2-3/4" higher still...def not lower than the front....better to be safe then sorry
Old 12-07-2007, 07:13 PM
ATOM's Avatar
it depends on the year, how much level in the front you need. supposedly 04's and 05's have one more spring. 2" levels out the 06+ and the 2.5" for the 04/05. this is just what i read on here, so it may be incorrect.
Old 12-07-2007, 07:18 PM
wxscpo's Avatar
I had the 2.5" kit on my truck prior to lifting and to the eye sat perfectly level, but measurement wise I was 1/2" higher in the rear. Right now my truck sits a little higher in the rear because I'm running 5" blocks, I'm thinking about adding either a 1" (do they make 1" leveling kits) or the 1.5" kit on the front of my truck.
Old 12-07-2007, 07:21 PM
they dont make 1"....but your truck looks pretty good right now...you dont want it to look like some of the lifts i see on here where the front is way higher looking than the rear...
Old 12-07-2007, 07:39 PM
CRF250rider1000's Avatar
You can always do a 3" block in the rear if you want it to sit higher in the rear.
Old 12-07-2007, 09:42 PM
hivoltagefx4's Avatar
I'm running a AS 2.5" and mine is dead level.
Old 12-07-2007, 09:48 PM
My '04 took a 2 1/2" kit to level it out and clear 35's on the front using the right wheels.
Old 12-08-2007, 05:14 PM
Forgot to say that I put a 2.5" kit on and my rear end still sits about 1/2" higher than the front
Old 12-09-2007, 05:29 PM
wxscpo's Avatar
You're right I don't want it to be higher in the rear, but it does sit a little lower in the front right now. Was hoping they made a 1" kit because I think that would be perfect.
Quick Reply: 1.5" AS Leveling Kit
