Trying to clear 285's
I was wondering if any of you guys knew a cheap way to lift my truck's suspension a couple of inches so I can clear 285/70/R17 tires without rubbing. I was thinking maybe add-a-leaf on the rear, and cranking the torsion bars 1-1/2 inches. Any thoughts? Words of wisdom?
Originally Posted by Skrewd
Nope Just Turn the Bolts! Its A lot easier if you crank the front end up off the ground, use a 1/2" Ratchet and a Cheater bar, and its a breeeeze, Just try to get an alignment after your done. Its not Crucial, But it will make your tires wear unevenly if you don't get one.
Originally Posted by JExpy
What about a 98' XLT Expy 4x4?
I've read through a few forums saying that 285/70/17's would be fine as long as i do something with the front airdam. Input?
