Best Leveling Kit? 04 F150 FX4
What's the best leveling kit? I've seen kits that do and don't require a strut compressor. I have a strut compressor, but the fact that some 2.5" leveling kits do and don't require the disassembly of the strut makes me wonder which is better.
I'm not necessarilly looking for cheap parts, but quality ones.
When I had my bronco, I just installed a complete suspension kit including new rear leafsprings (no blocks), there was no 'leveling'.
thanks,
-newbie
thanks,
-newbie
A lot of people here are running the Autospring 2.5" spacers with no problem. They do not require the use of a spring compressor and do not effect the shock length like the type that installs between the spring and the seat.
The Bilstein leveling shocks are another way to get there, but more expensive and more labor intensive.
Either way an alignment will be necessary to correct the toe settings.
ACTUALLY forget my response above. I just re-read your post. You said the AutoSpring does NOT require a compressor.
I WAS wondering how you could install a 2.5" spacer within a strut and get away with it without relacing the stock strut with a longer version.
Originally Posted by LariatSCrew04
Originally Posted by kjohnson1
wow, those look like quality pieces. I just ordered them. So if I get a full suspension lift later on these spacers will not be useless? Or will they?
Originally Posted by chapdog
Depends which lift you choose.Fabtech for example uses a longer shock and your stock spring so you can stack it on top and rize has a higher mounting point on the top of there sub frame so you can stack it on top with there lift as well but BDS and Pro Comp both give you a big spacer just like the Autospring one but bigger and mount it on top so it wouldn't be a good idea to stack the 2 together with those.
I am considering the AS 2.5" kit for myself, but I am still undecided on the issue of stretching the front suspension components. There does not seem to be a consensus one way or the other on this forum, so you have to read a lot of old posts and make a decision for yourself.
The smallest lift which maintains the factory CV angles is a Rancho 4", but the cost is 10 times higher due to all the parts and pieces needed. Plus, if you are not going to do the work yourself, the price of the labor is much higher for a full lift kit. (As you would expect)
KR-Texas
PS. The reason I like this site is because most of folks on here are civil.
KR-Texas
KR-Texas
KR-Texas
What is this "stretching" that you speak of? Please explain more.
Also, I noticed that Auto Spring sells a set of replacement set of rear blocks should the rear of your truck sag after installing the Auto Spring 2.5" spacers. What's that all about?
Here are a couple of the posts which reference the ongoing CV angle debate:
https://www.f150online.com/forums/sh...ight=cv+angles
Do a search on "cv angles" with the quotes and you will find a lot more.
Here is what your front end will look like after installing the 2.5" leveling kit:
The CV shafts are parallel to the gound and in a straight line on a factory truck. Plus, the upper ball joints are not turned at such a severe angle like the top edge of the picture shows.
Do the angles affect the longevity of these components? Some people say yes and others say no, based on their own personal experiences. The over-riding trend seems to be the ones who take their trucks off-road have more problems with leveling kit angles than those who do not.
As an added point, every person I have asked who works at a suspension installation company (4WP, 4W Online, local suspension shop, etc.) has told me they have not had problems with them. In fact, they all recommended them as a safe way to level my truck. These are companies who sell a lot of leveling and suspension kits, so they have a vested interest in keeping their customers happy. Plus, they make more money selling and installing suspension kits, so there is no financial incentive to push the cheaper spacers.
If you plan to tow a trailer or if you want your rear higher than level, the rear spacers will help you in that regard. I have never heard of the rear sagging more after adding a leveling kit, but your truck may look like it is sagging due to the height difference.
KR-Texas
KR-Texas
KR-Texas
KR-Texas
