What is a leveling kit
A leveling kit will raise the front end of your truck. If you have a 4x2 most people use a 2" and a 4x4 a 2.5". The benefits to these are 1. that it will give your truck a level stance 2. you will be able to fit larger tires. On a rather baised opinion the autospring is one of the best you can get it on Ebay.
+1 on the Autospring
My 2.5" kit is being shipped as I type this.
IMHO, the kits that relocate the top strut mount are superior. They allow the full range of travel of the spring and strut, versus adding height by changing the spring compression or altering the length of travel of the strut piston itself. You still get the factory ride, just the front strut frame mount is 2.5" higher then it was before.
If you end up investing in a leveling kit, I'd recommend Auto Spring.
as stated above autospring is probably the most popular on this site... here is a pic it sits on top of the strut. read this thread https://www.f150online.com/forums/sh...spring+install
