Cracked my frame...
Cracked my frame...
I was visiting an old high school teacher today when he looked at my truck and said "Is that cracked?" I look, and sure enough my frame is cracked pretty much directly above the rear axle. The crack was right at the front of the bump stop, and went a little over half way up from the bottom of the frame. It also went about a half inch across the underside of the frame. I did get some pics, but they're on a friend's camera so I probably won't be able to post them for a day or two.
Anyway, this same friend works at a metal shop so we headed over there to fix it. First they welded the crack itself, then grinded that weld down and welded a plate over the whole thing. I'll post pics later.
I was just wondering if this is a known weak spot on the frames, or if this was just a fluke. Also, it wouldn't hurt for anybody who does a lot of off roading (like myself) or otherwise drives their truck like trucks are supposed to be driven, to check out that spot on their frame to make sure they haven't had a similar problem.
Here's a news flash for you,.....
If you are offroading your truck hard enough to crack your frame above the bump stop, you are not driving it the way a truck was meant to be driven!
You need to step up to a four-link long travel suspension. You could also benifit from some roll bat bracing. Your frame is being twisted past it's designed limitations because of two reasons. First is the limited suspension travel, second is the frame's flexability.
Originally Posted by wetanner
Just wondering if you are the first owner of that truck?
