Sponsored by: DashLynx
Shuttering and shaking on startup, 2010 5.4L
Old 02-20-2017, 01:29 PM
Legendsdie33's Avatar
First post as I have looked everywhere online and can't find a thread or YouTube video describing what I'm experiencing . I have a 2010 F150 Fx4 5.4L (195,000 km's) and my biggest problem I'm having is that when I start the truck , it just continues to turn over and over and over and shake a bit before finally barely starting up . A ton of exhaust comes out the tailpipe before the idle settles down . Once the truck does fire up, if I shut it off and try to fire it up again , it fires up immediately . Only after it has sat for 4-6 hours does it do the shuttering startup . I had the fuel pump and sending unit replaced thinking maybe it was having a hard time getting fuel . I did the spark plugs myself last summer with no problems , I didn't however replace the coils . I know 5.4's are notorious for timing problems and solenoids , and I have only once had the truck shutter and knock at idle while through a drive through so I know the solenoids probabaly need replacing . Does anyone have any advice on what to go to next? i hope it's just coils for now . I've done a lot of research on these engines and can diagnose a lot of problems but that has me STUMPED. Thanks
Old 02-20-2017, 02:15 PM
Codes?
Old 02-20-2017, 02:57 PM
Could be too much fuel - flooding - due to leaky injectors.
Old 02-20-2017, 05:25 PM
Roadie - getting codes read tomorrow - also the exhaust smells pretty fowl , my guess is that it's turning over and getting too much fuel trying to startup which explains all the exhaust , but why is it turning over and over and over and not firing ? That's why im thinking its coils . Just find it odd that it only does that after it's sat for a few hours - if I run to the store and back it starts up no problem after the initial crappy startup. Thanks for the replies guys , this has me stumped .
Old 02-20-2017, 07:50 PM
There are a couple of sensors that tell the computer the engine is cold and causes the fuel injectors to pulse longer. Maybe one of those sensors.
Old 02-20-2017, 09:05 PM
If the injectors are leaking, it takes time after you shut it down for them to bleed down into the cylinders - if this is what's happening you are very close to having a hydrolock. Does it start if you hold the pedal to the floor?
Old 02-21-2017, 11:16 PM
stopped by my mechanics today and the only codes that were pulled involved the cam sensors , I had an incident a few weeks ago where the truck shook while idling at a drive thru which I figured would be VCT solenoids or phasers .. it's a 5.4.. I knew that was coming , but nothing that points to the rough start. Then I showed him a video of the rough startup with the smoke from the exhaust and he believes my head gasket is leaking . I bought some iron tite today , I'll post if that changes anything over the next few days .
Old 02-21-2017, 11:18 PM
after talking to my mechanic today he seemed to rule out injectors , who knows for certain really , but he felt pretty confident in saying the injectors were functioning properly . I use injector cleaner every couple of oil changes just to trunk stay on top of it .
