backup sensors, strange behavior
Twice now, on my new f-150 I've put the truck in reverse and the right rear backup sensor comes on full, as if I'm right near something. The solid tone stays on. It will keep doing that for a few hours when I put it in reverse then later on it will stop doing it. It's happened twice in the past week.
I guess I've got to take it in to be looked at but wondered if anyone else had this issue and how it was resolved.
Thnx.
If it happens again, I'd recommend swinging by your dealership so you can show a tech. How many miles are on your truck? I'll do what I can to assist as well.
Crystal
Anyway, thanks for responding on this....You are acting very strange for an automobile company, responding personally like this. This is my first Ford. Not used to anyone caring much.
No, and it just started doing it. Occurs condinuously even after I'm out of the garage with nothing around the truck at all. A steady beep and the red line around the truck and right sensor block in the display.
Crystal
My 2014 F-150 has backup sensors which worked flawlessly until this winter. Now, they work intermittently. I had the truck into the dealer for an oil change, and asked them to check connections. They said they did, but they couldn't fix it until the problem appeared again. Starting the truck to drive away from the dealer the sensors didn't work. So I summoned the service guy, and he said they want the truck for the full day to take apart the entire wiring harness to see if they can find an issue. While I like these guys, this is effing scary in my book.
They didn't work today until I took it to the car wash, and now they work again. The issue seems to be dirt related, but not always. In the past, they worked through salt & dirt to a degree I found astonishing.
I get the Check Rear Park Aid light on sometimes, but not always. When I don't get this message there is no check mark in the rear park aid box, which is a subtle message with the same outcome.
So I've had this problem happening....not all of the time, but about 80% of the time! I just bought a 2018 F-150, which was a Ford Service Rep's vehicle previously. I wanted to have the recalls done, as well as any work that might need to be done under warranty, before the original manufacturer's warranty ran out. I bought it through my relatives dealership in Minnesota, and one of their mechanics looked it over. He said that the pinion seals were leaking, but other than that...looked in pretty good shape. They didn't have time to get it in to the shop to fix it before I had to leave town after picking it up because they were already booked up. So I said no problem..I'll get the work done when I get home with the truck at our local dealership. Since then, the right reverse sensor has been going off with a red light and a constant beep usually...sometimes its only a yellow light and an intermittent beeping. But mostly its acting as if i'm about to hit something when there is NOTHING behind me! And i'd say it does this about 80% of the time when I put it in reverse. There seems to be no logic or pattern to when it does or does not do it though. I've tried wiping sensors clean, I've taken it through the car wash to clean it. I took a video to show the dealership. Well, of course, when I took it in for my appointment, it didn't act up that day! They had my truck all day and they said they couldn't get it to replicate the problem and there were no codes showing any problems or issues. So they said there is nothing they can do....even though they know there's a problem, I showed them the video i took of it happening. And like clockwork....when I go to pick up my truck....hop in and immediately it does it again! This was after all the mechanics had left for the day though, so when I went inside to tell them to come look at it now...nobody was available to do that.
Now...this might just be one of those things where you say "eh...its annoying, but no big deal" but its a VERY big deal! Its a SAFETY issue! The other day, I was in a parking lot, which was a "one-way" directional flow parking lot. There was no moving cars anywhere in sight when i got into my truck, I put it in reverse and the stupid sensor was going off with a constant beep....i was backing out of the parking spot, turned to put it in drive and go forward when i see another car out of the corner of my eye RIGHT NEXT to my truck....i have no clue how we didn't hit! But that idiot was going the wrong way down the parking lot! I didn't see this person, obviously, but my cross-traffic warning would have alerted me to that idiot if it would have been allowed to work! But since the right rear reverse sensor was going off....the cross-traffic alert didn't go off! If I would have gotten into an accident with my new truck that doesn't even have license plates on it yet and still had a temp reg for transportation because of this problem....i would have been pissed! So i want this fixed! It seems its an issue for many people....but the dealership says they cannot do anything unless its happening when they have it in their possession. Which it apparently didn't do they whole day they had it last week! ugh! typical...take your car to get it fixed and then it acts all normal lol.
I'm the original poster for this thread. Mine did this for a year while new, but off and on like you. Eventually they took the connection off and cleaned it and whatever else they might do to it, maybe electrode grease or something. Now it's fine. Been fine for a long time. My f150 is a 2015
