Intercooler temp gauge
Old 06-27-2003, 12:43 PM
LatemodelRacer2's Avatar
Is 100 degrees low enougth to do me any good or does the fluid stay below 100 during normal driving?It has a range from 100-250.
Old 06-27-2003, 02:48 PM
2002Bolt's Avatar
I dont think that gauge will be worth your time. I believe that the temp in the intercooler is right at 100 maybe less depending on outside air temps. But if you could find one that went from say 50-125 that would be intresting to see
Old 06-27-2003, 03:30 PM
QIKSLVR's Avatar
while your screwing with your intercooler, figure out a way to put a manual switch on the pump so I can run it between passes at the track. So far no one has been able to help me come up with a way to do this. Also saw a sonic blue 03 in town last night, do you know who it is?
Old 06-27-2003, 03:39 PM
Silver-Y2K-SVT's Avatar
IC Temp Gauge Results
'Bolt:
I have a Cyberdyne digital gauge on the IC (with the sender right at the outlet of the IC radiator) and have made a lot of observations over the last year. The Cyberdyne unit reads from 70 degrees F up to way-too-high-for-the-IC degrees F. Here is what I know...
At steady state (off the boost, long highway cruise, not tailgating), the IC runs about 10-12 degrees F over ambient during the day, 6-10 degrees F over ambient at night (pavement heating effect).
If you hammer the throttle open on a good 0-120 MPH run, you will put 6-10 degrees F into the entire fluid inventory of the IC circuit. Each degree of IC temperature will cost you around 1 RWHP, and around 0.01 seconds in the quarter. Thus, the 10-odd degrees you put into the circuit will cost you around 10 RWHP and about a tenth. Those of you who like to hot-lap at the 'strip, take note.
The IC circuit takes an eternity to reject accumulated heat. At 60 MPH, off the boost, and not tailgating, it takes well over a mile to reject 1 degree F out of the IC circuit.
When you drive a while (think - the trip the the 'strip), get the motor up to operating temperature, then shut the truck off, all of the fluid in the IC core (which is a considerable portion of the total inventory), which is trapped within the general confines of the engine, starts soaking up heat. Lots of it. If you drive to the 'strip on an 80 degree day (daylight hours) and stay off the boost, your IC circuit will be at around 90 degrees F (see above). If you shut the truck down and wait for the engine to cool for an hour or so, the IC fluid will be around 110-120 degrees F once you restart and mix up the scorching hot fluid from the core and relatively cool fluid in the radiator and reservoir. This will cost you as much as 30 or 40 RWHP and 3-4 tenths, relative to the IC fluid at ambient.
Accordingly, it pays dividends to wire up a switch to allow you to circulate the IC fluid with the truck off. Do a search, but beware. There are a lot of dead-wrong ways to wire this and really only one right way. Props to our man Noel for being the first to get it right, although his description is a bit cryptic. It's actually a bizznitch of a job to really do it up right, but it's worth it.
If you nose right up to the azz-end of a semi on the highway, you will pick up 2-4 degrees F in the IC circuit from reduced airflow over the IC radiator.
In summary, putting a gauge on the IC circuit returns a lot of data and affords some advantages if you choose to manage the IC temperature, but will, on the other hand, drive you insane. Certifiably so.
By the way, I also have a Cyberdyne at the inlet side of the MAF, but that's for another day. Suffice to say that if you get stuck in traffic on a hot day, you might see intake temperatures 60 degrees over ambient (60 RWHP or so, plus the IC effect).
Old 06-27-2003, 03:41 PM
IC Pump Switch
Quick':
Give me a second to take a shower, then I'll post DETAILED directions on how to wire the switch the proper way, with an LED indicator at that.
Be about a half-hour or so.
Old 06-27-2003, 03:49 PM
C BROWN's Avatar
Re: IC Temp Gauge Results
Originally posted by Silver-Y2K-SVT
'Bolt:
Thank you for the info; I have never see anyone post such usefull info. Also I will be also waiting for the wiring info.
Oh, to add to what you said; I have a sensor at the air filter and have see what you did. It heats up quick! I used a $15 setup from WalMarts fishing department that is used for coolers and such, but works really good
Old 06-27-2003, 03:53 PM
easterisland's Avatar
cool.
Old 06-27-2003, 04:06 PM
And By The Way...
All:
For a gauge to be useful in the IC circuit, you need to be able to differentiate between small temperature increments (read: 1 degree F or better) over a fairly narrow range (read: 50-130 degrees F or so). Thus, any of the analog gauges that we prefer are fairly, if not totally, useless.
The Cyberdyne unit is pretty ugly and pretty rice-y and can be read by the car following you in traffic, but a very effective choice. If it only read down to 30 degrees F or so, it would be PERFECT for the task.
Also, have fun rigging up the sending unit. I used a brass "T" block with properly-sized hose barbs or both ends, double hose-clamped. On the "T" side, I threaded in a brass fitting that would accept the sending unit. The sender also needed to be grounded, so I needed to drill and tap a small bolt into the "T" block, then solder the ground wire to the head of the bolt. All of the above were painted black, and it doesn't look half bad while adding about 800 pounds of weight over the front axle.
Old 06-27-2003, 05:01 PM
IC Pump Switch Instructions
Here we go, gang. I'm not looking under the hood now, thus working from memory, so please excuse any generalities.
First, you'll need to select a position for mounting the switch and indicator LED. I used the bottom of the cupholder under the stereo head unit. No drinks allowed, so no problem there (8000 miles on the cleanest 2000 model you've ever seen).
You need to get a switch. Specifically, a double-pole double-throw (DPDT) switch. Also, you need to select one that is NOT a "center-off" type. Specifically, one that is either ON position one or ON position two. Most of the automotive switches that you are going to find are "center-off" units, and thus not suitable. I hit the local Radio Shack, and found a couple suitable DPDT switches, all intended for 120/240 V service, none with the high-amperage capability of a typical automotive unit. I got a 10-amp 120 V unit, and it has performed fine. I wouldn't go any lower than that for amperage rating, however.
Basically, the double-throw part means that you have a selector switch (a switch that selects between circuit "A" or circuit "B"). This could mean either a single input going to device "A" or "B", or a single device being driven by input "A" or "B". The latter is our situation - a single device (the IC pump) being driven by a choice of two inputs (either the normal switched supply off the relay or directly from the battery).
The double-pole part means that effectively you have two separate switches bound together in a "gang" - when you throw the switch you effetively throw two electrically independent switches simultaneously. We will use one to drive the IC pump and the other to drive the LED indicator.
You will also need to get a proper LED indicator. Get a surface-mount unit that is properly ballasted (with a resistor) for 12 VDC. If you just geat a bare LED without the resistor, it will have the lifespan of a fruit fly, possibly less.
You also need two fuse holders and two matching 10-amp/12 VDC (or 15-amp) fuses to protect both of the input circuits. We don't want to torch your 'Bolt, do we?
Use good 16-gauge wire or better, solder all of the joints, shrink-tube the joints and friction-tape the WHOLE HARNESS liberally. Do it right, and do it once. A million black zip-ties willl be handy, especially if you're fishing the harness through the firewall. Most importantly, DISCONNECT THE DAMN BATTERY BEFORE YOU DO ANYTHING! Consider yourself warned.
Now for the wiring. Recall, we'll be wiring all of the IC pump stuff off one pole of the switch and the LED stuff off the other pole. Looking at the "back side" of the switch, the contacts for each pole will be three lugs in a row (two rows of three).
Look at the IC pump. You have a ground wire (black) and a "hot" wire (white or a bit yellow-ish). The "hot" wire can be traced back to the "out" side of a big relay high on the firewall on the passenger's side. You need to cut the "hot" wire to the IC pump at any point that is convenient. The portion of the wire that is still attached to the pump needs to be run to the center lug of the "IC" pole of the switch. This is our single "out" from the switch. In other words, regardless of which position (which "feed") is selected, the output will be to the IC pump.
The other portion of the IC "hot" wire (the portion attached to the "out" side of the relay) needs to be run to one of the two available input lugs on the "IC" pole of the switch. Attach it to the lug corresponding to the position on the switch that you want to be "normal". Now think for a minute - when the switch is in this position, you have just "repaired" the cut in the IC "hot" wire. Simple, right? Also, make sure you wire a fuse in-line on this wire.
Now, from the remaining input lug in the "IC" pole of the switch (on the side of the switch that you want to correspond to "pump running with the engine off"), run a wire (with a fuse wired in-line) to the "in" side of the same relay that the other wire was run off. The "in" side will have a pile of thick wires with ring terminals bolted to a thick threaded lug. Solder an appropritely-sized ring terminal to the wire and bolt it onto the lug on the top of the pile. Make sure that you have the battery disconnected, as this lug is fed directly off the battery and is always hot! Again think - when the switch is in this position, the feed is directly off the battery and direct to the IC pump. The pump will come on instantly when the switch is thrown and will run as long as there is juice in the battery. Thus, with the truck running, the pump will function normally, but you'll be looking for a jump if you forget and leave the switch in this position too long with the truck turned off.
Now for wiring the LED. You will want the LED to be lit when the switch is in the "pump running with engine off" position, as a warning that you will be walking home if you're not careful. Right? Anyway, you again will have three lugs available on the "LED" pole of the switch. We will only be using two. This time, the center lug will be the "feed" (as opposed to the "output" as it was used on the "IC" pole). You need to solder a short jumper wire from the center lug on the "LED" pole to the lug on the "IC" pole corresponding to the wire connected to the "in" side of the relay on the firewall (the "pump running with the with engine off" positin of the switch). Thus, the center lug on the "LED" side of the switch will be always "hot" (always connected to the battery, through a couple of connections). On the remaining lug on the "LED" pole of the switch corresponding to the "pump running with the engine off" switch position, connect one of the two leads from the LED (I think theat the lead with the resistor would be best). The other lead from the LED needs to be connected to a good ground - I prefer to solder directly to an existing black ground wire somewhere under the hood - they are everywhere.
Anyhow, now on the "LED" pole of the switch you have the center lug always hot, and when you flip the switch to the "pump running with engine off" position, you cunnect this 12 VDC source to one of the legs of the LED. The juice passes through the LED and to ground, thus lightting the LED whenever the switch is in this position. In the switch "normal" position, the LED is disconnected from the power.
That's a lot of typing, but I hope that some of you benefit from this. I can tell you that it just about made my head explode working this up from just about zero, with the exception of Noel's rough instructions located via the search function.
This is the only truly proper way to do the job - by "proper", I mean no cutting into the computer harness, no back-feeding juice to the "out" side of the relay, and NO COB JOB WIRES JAMMED INTO THE FUSE BOX.
Old 06-27-2003, 05:10 PM
Eds 01 Lightnin's Avatar
On this same subject...has anyone tried "water Wetters" or a similiar product in the I/C to lower the temp?
Old 06-27-2003, 05:27 PM
Speedin Bob's Avatar
Location: On the side of the Road attempting to explain 135 miles per hour
Re: IC Pump Switch Instructions
All that and a cup-o-coffee.
Old 06-27-2003, 06:36 PM
qikslvr
call me 522-3374 and ill help you hook it up like mine.
Old 06-27-2003, 10:33 PM
Tim Skelton's Avatar
Silver-Y2K-SVT, GOLD STAR for the best damn posts in recent memory.
Thanks!
Old 06-27-2003, 10:43 PM
C BROWN's Avatar
Thanks!
I'll second that; I actually printed it out so I would have the instructions
Old 06-27-2003, 10:48 PM
. . . The IC circuit takes an eternity to reject accumulated heat. At 60 MPH, off the boost, and not tailgating, it takes well over a mile to reject 1 degree F out of the IC circuit. . . .
That's typical. As I posted here a couple of days ago, most OEM air--to-water intercoolers work well at pulling the heat into the coolant, but work less well getting the heat out of the coolant.
I would love to see the same data taken with JDM or JL's heat exchangers.
Once again, awesome post. Can I copy it to my Web site (with proper attribution, of course)?
Quick Reply: Intercooler temp gauge
