Wierd Idle
Old 03-03-2002, 08:10 PM
BULLDOGG01's Avatar
Question Wierd Idle
MY 97 F250HD HAS A WIERD LOW IDLE-EVERY MORNING I GO START THE TRUCK & LET IT WARM UP FOR@10 MINS.WHEN I GET BACK OUTSIDE THE IDLE DROPS WAY DOWN-ALMOST TO STALL-THEN COMES BACK UP-IT DOES THIS BACK & FORTH UNTIL I BEGIN TOP DRIVE-IT DOESNT DO THIS EVERY DAY-AND IT SEEMS NOT TO BE PROBLEM WHILE I AM DRIVING-IVE HAVENT HAD THE TRUCK FOR A MONTH YET, SO ITS STILL UNDER WARRANTY-IVE BROUGHT IT BACK TO THE DEALER & THEY REPLACED THE TPS THE FIRST TIME-THE 2ND TIME THEY REPLACED THE ENTIRE COMPUTER-STILL NO GOOD-THE C.E. LIGHT ISN'T COMING ON SO I REALLY DONT KNOW WHERE TO START LOOKING
IN CASE THIS HELPS 97(OLD BODY) F250HD 4X4 351 C.I./AUTO @51K ANY HELP WOULD BE GREAT SINCE DEALER HASN'T FIGURED IT OUT YET
Old 03-03-2002, 09:20 PM
Ford4ever's Avatar
Sounds like an ignition timing problem. What is causing it i don't know, could be a variety of things. Sounds like the techs are throwing parts at it instead of trying to do a good diagnosis. The good thing is when you bring it back a third time you can threaten with lemon law. That should make them bring in there master techs and regional tech specialists, they should be able to fix it.
-Jon
Old 03-05-2002, 09:08 PM
BULLDOGG01's Avatar
since my last post...no problem i will wait & see if it comes back-thanks for your advice i will not be such a nice customer if i have to go talk to those knuckleheads again
Old 03-06-2002, 10:35 AM
Tweeder4x4's Avatar
idle
I have a 93 5.0 4x4 and it has done the same thing since I bought it. I haven't figured out what it is either, but it doesn't seem to hurt anything. I'd like to know what it is if you find out though.
Old 03-06-2002, 05:20 PM
BULLDOGG01's Avatar
if it comes back i will be back at the dealership...& i will let you know what it is. hopefully it is gone forever-but i think that 's just wishful thinking
Old 03-06-2002, 09:44 PM
inski21's Avatar
Mine surges (almost stalls) during warm up only if the defrost(AC clutch) is on.
I think the volt-regulator in the alternator is going bad. So I don't warm it up with defrost on.
I load tested the battery and it didn't surge for 2 weeks...this is what lead me to believe its the alternator. Charging sysytem tested good at the time of test.
Also, AC charge is low. Just a couple of things to think about.
The only bad thing that might be happening is the Cats might be loading up during this cold exhaust situation. Takes a few moments for the computer to figure out the idle, then it mellows out.
Old 03-07-2002, 09:53 PM
BULLDOGG01's Avatar
inski21
its been pretty warm around here the last couple of days-so i havent needed my defroster-& i havent had any problems...the next cold day(if we get another cold day) i will have to do a little experiment & put on the defroster to see if it happens again-i will let you know how it goes-thanks for the suggestions
-nate
Old 03-09-2002, 12:47 PM
karnage's Avatar
idle problem
Sounds like the ecm isn't compensating for the extra load that
the defrost/a/c is putting on the engine kicking on and off.Maybe the idle bypass valve is going bad or is dirty.It's one of those things with speed density does.
Old 03-10-2002, 08:43 PM
SVOMike's Avatar
Sounds like the ISC motor. 9 out 10 times the ISC fixes idles problems when you do NOT have a check enigne light.
Quick Reply: Wierd Idle
