No start cranks but slow or no crank
87 Ford f150 4.9 inline 6 About threw months ago just completely died while running at idle so I called AAA to jump it to see if the battery was the problem an it was good and he said that it's probably the fuel pump so I towed it back home and put a new fuel pump on and still no start then I started to look at the distributor an it look pretty bad so I replaced that with the ignition module an re-timed the engine still nothingask then I replaced the spark plugs and all the plug wires and still no start so the battery started the weak and was already 5 years old so I just got new battery and still no start but I noticed that the starter was smoking. Everything is getting power so I don't understand what the problem is would appreciate any feedback with help this problem
This could be as simple as a bad ground. It happens a lot - bad connections cause a lot of problems.
First thing to do is check all the connections in the battery/ starter circuit (both ends) and make sure the connections are shiny clean and tight.
If that doesn't help, you may be looking at a new starter or one of the cables could be bad.
It's always possible your timing chain jumped (5.0, 5.8, not 4.9) and is causing this, but start with the connections.
The ground wire can go to either the block or the starter mount bolts.
Even if the new + cable makes it crank better, go over all the connections - battery, solenoid, starter and bottom ground connection. You don't want to be back messing with this again.
Undo them, clean up the wire end and the nut contact surface with some sandpaper and then snug them up good. Don't break them, but just make sure they're all tight.
If this problem comes down to a bad positive cable - cross your fingers - at least you have some new parts on your truck. Probably could have done without the aggravation and expense though.
