4.9 missing?
4.9 missing?
i've read every misfiring topic there is but couldn't find any with the similar problem: at low idle and low rpm it runs good but from the moment i go past 2000rpm it starts to drop in rpm so when i do 2500 it jumps from 2500 to 2200 -2300 not always the same amount and not always at the same rate but the higher the rpm the more it does
spark plugs and wiring+distributor cap and rotor.
bushings have no play, changed coils, still the same,
forgot to mention this came after the truck didn't want to start, i must have had the fuse blown giving power to the eec since this one didn't get any power, after i put a seperate cable + fuse in going to the eec relay it fired right up,
injectors is not the problem either since i'm running carbed propane (not this install aswell: when i switch back to gas it still has issues)
jumped timing? how do i check on these trucks?
