MAF conversion
As far as I know yes. Any 88-93 Mustang computer should work, because they did NOT have an electronic transmission. So a manual will work, but is not required.
Here is some more info:
http://www.fordmuscle.com/archives/2...AirConversion/
Thats good! That makes it a little easier to do since I have a C6. Also, has anyone checked out this; http://www.diyautotune.com/catalog/m...ang-p-418.html They say you dont need the MAF sensor with this kit.
13726548 mustang f.o
15426378 truck 5.0 f.o
Edit: But I'm willing to bet that if they got that far with their product you may be able call them and see if they make a kit for the truck 5.0. I imagine it would be simple for them to reconfigure the firing order.
It would be more complicated with that set up in the long run IMO. You'd have to tune it everytime you did something to the motor. With MAF it'll detect the changes and make most changes accordingly. A tune helps with a MAF set up don't get me wrong, but it would run fine without one.
BTW. To the o.p. Tuning a system like megasquirt is not for the novice. If this is the route you want to go, make sure you can get good tech support for your system. There is also other EEC tuning companies like Motorvation and Tweecer. Motorvation can take your mods and build a chip for it. The downside is everytime you want something changed, your sending the chip back to them. Tweecer, OTH, offers a real time, chip based tuning system for speed density. They have a list of ecu's that they support. If yours isn't supported you could find one that is. The nice thing about Tweecer is that they do support Speed Density and MAF. The Motorvation site isn't very informative but I've talked them on the phone. I was referred to them by Troyer Performance cause they don't like Speed Density.
Go to:
www.Tweecer.com
And see what you think.
Also I found this if you do want MAF. A little pricey but looks like everything is there for a swap.
http://cgi.ebay.com/ebaymotors/Ford-...3#ht_500wt_981
This the route I think I might go.
Yeah I checked out Tweecer last week. Looks like a nice setup. The megasquirt guys sent me an email and they do have this for a truck. Their system uses a MAP sensor they said. As for the firing order, yes you have to install a different cam and change the injector firing order. I have a tuner on my atv and built the fuel map for it so I think I would be ok with tuning. I know just about every MAF conversion I have seen, they list a 88-93 Mustang eec iv. Maybe these guys are having them re tuned for the truck. I just found the Cobra one cheap and thought it might work.
What other reason do you need? I've thought of every other way I could build some performance out of my 5.0 and its really not that feesable without MAF or the megasquirt set up. I like the setup on eBay cause it seems I won't have to change my cam or injector timing.
Does anyone know a good way or link to get rip of all the smog and egr stuff? I know that you can get a smog pump eliminator pulley and egr delete block off plate. My thing is, what about all the vac lines? Ive heard to plug them all off. But what about removing them all together. Truck also has no cats.
Despite not having cats the pump still directs air to the heads to help burn off unburnt hydrocarbons. If these hydrocarbons got to the o2 sensor it will create, imo, undesired results. I don't know that you could tune around it. which would make it a problem passing an emissions test if you have them where you live. Also you'd have to block off all the passages to the heads as well. plus it would depend on the heads you plan to swap. I don't know if the Gt40 heads have emission provisions or not. personally I plan to keep all of the emissions in working condition because the eec depends on it to help calculate fuel and timing properly. IMO the more power that you make with mods, the less parasitic loss you'll have by turning the smog pump.
BTW with you being new to the site, I must warn you about talking about removing emissions equipment. As it is illegal and some other members might come down on you pretty hard about it. they seem to think it might get the site in trouble talking about breaking the law. personally I feel its your truck, idea, and money do what you want. just trying to give you a heads up is all.
