biggest tire for 4" lift? how to squeeze extra lift
Hey guys Im currious as well as would love to see what you have under a 4" lift. I've been told 35's but it would be tight. Also besides a body lift, what are the other options for more lift with these models? Im looking at a truck that I'd like to clear 36's with but its only got 4" under it as of rite now. Want to check all my options before purchase
Thanks guys
again pics would be awesome.
Thanks guys
36's? With only a 4" lift I am sure you would have to reduce backspacing as much as possible and trim a crazy amount off both off the fender and bumper...and you may even need to trim the rear some for that to avoid hitting when you go over a bump...
Im not even sure 35's would fit without a spacer and some triming with only a 4" lift..."Gain additional tire clearance for 33" tires and get a cool new look with this Tuff Country Ford F150 4" lift kit" I got that from here-http://www.suspensionconnection.com/cgi-bin/suscon/248104.html
If you want bigger you would have to go higher...Ive tried the fit bigger tires with less of a lift with a toyota back in high school-bottom line is be safe, lift it higher! lol
cant do spacers on these ifs u have to drop the ibeams and either lower or get extended ratius arms ur better off just getting a 6 in supenchen lift from rough country
buddy of mine had 38s with good clearnce on a 94 f150 4x4 with a 6 in suspenchen and a 3 inch body
remember the bigger the tire the more stress if ur going to lift get new bushings ball joints tie rod ends make sure ur bearing are packed so ur not breaking stuff
and dont forget an alinement or else ull be chewing up front tires like its the trucks job
I thought I could use coil spacers on these years ... If I do get this truck o think I'll just add a body lift then I want to run 35's or 36's I don't need bigger than that . Unfortunately I don't have time or money to rip off 4" kit and replace with a 6" I'd love to but if I had the money I'd just by a stock truck than lift it myself
Yes. Everything but the '02 and '84 can be for sale.
Adrianspeeder
PS:sorry rclark12 for thead jacking
