battery light
battery light
ok so after that "hurricain" we had i started up my truck n my battery light was on so i turned my steering wheel to make sure i had power steering so i poped the hood serp was good so i drove it home volt gauge was reading normal ecept i turned on my defroster n the gauge droped alot but not into the red. so i drove 2 hours back to my house no probs so i had a spare altinator that i knew was good slapped it on went out for a wile then came back on. so i cleaned up the cables and i started the truck and pulled the positive off the battery n it stayed runnin n i took a test light from the ground to the positive battery cable "still off the battery" and its chargin
im stumped
if you didnt know i have 90 f150 4.9 t18 3.55 4x2
im stumped
If you checked the pos cable with it disconnected, it's still going to show the output voltage of the alt because you still have to put the neg side of the meter to grd. Sounds to me like the batt is on its way out as the light comes on when under a load and you already eliminated the alt.
