My custom built F-250 update.
Here is a video I did on a walk around of my F-250. I still have much to do, but its getting there. So far, I have 4 years into it. I hope you enjoy!
http://www.youtube.com/watch?v=WsKJ8GIJ1qE
The front brake hose has two fitting on it, the metal brake line that comes from the master cylinder goes directly into the hose through the shock tower, then on the hose there is another fitting coming out at a 90* angle. Where is this supposed to go? Or where does it go on your truck?
You can see what I mean at 1:14 in your video when you are showing off the shocks.
Love the truck by the way, I like the interior actually.
How do you think that TTB axle will hold up to your plans? or is a SAS in the works?
The rubber line goes to the caliper, and on the inside of the frame on the back side ( that you cannot see) goes to the passengers side caliper.
We have some big hills out in these woods, when I park the truck to load a few logs to the sled, I want the truck to stay put! And its also fun for heating up them back tires with this 5 speed.
I have a dana 60 for the rear, I still have to tare into it... And I just have to see what I come across for the front still... I WILL have ARB air lockers, in both the front, and the rear. And a atlas transfer case, along with added air bags on all 4 corners, for them extra heavy hill side pulls.
Okay so what did it originally go to?
Reason I'm asking is when I bought my truck the brake lines were destroyed and the new line came with that extra fitting, not knowing where it was supposed to go to and not finding anything in books I just put plug fitting in it.
How does that line locker work? I'd be interested in that for the same reason you are, these m5od trans don't hold in gear well, the parking break is good, but line lock is great.
I just have the line lock between the two, the "T", and the master cylinder.
The line lock is just a valve. here is a link to the one I have.
http://cgi.ebay.com/ebaymotors/BRAKE...#ht_1119wt_883
Do not use the line lock for long time park. Do not depend on the line lock alone for safety. You can also get electric line locks. Just do some research, they are great for short time use for added park locking.
Next chance I get, I will make a video on my brake system for you. my you tube is: http://www.youtube.com/sirwitchback
Good luck my friend!
Thank you for your input, and time.
