Tow Hooks
on
Did you read that caption? No, they don't simply bolt up to the older frame horns - you have to fabricate brackets. The ones I made don't interfere with the accordion crumple zones.
Check how the brush guard mounts to find out if these will interfere, but you can always attach the eyes (or some others) to the brush guard if it doesn't already include hooks.
And most brush guards for these trucks are just cosmetic - they can't actually stand up to knocking down brush, so be careful using one as a pulling point, no matter who put the hooks on it.
If you want something that will actually bump, you have to build it, or buy a REAL off-road bumper, like ARB, RanchHand, Reunel... I built mine.
I see what you mean now. About how much does it cost to fab up your own if you don't mind me asking? The one you made looks real good. So this would be one of those cosmetic ones I am guessing: http://www.autopartswarehouse.com/sk...or+Accessories
on
For those brackets on the '93? I had that material & I did my own measurements & cutting - I only paid $20 to get the welding done. If you dropped the truck off & asked someone to do the whole job, you might pay $50-200 just for the brackets.
If you mean my bumper... That took me a few years just to finalize the design (which naturally got revised during & after construction). Then I bought the material a little at a time, worked it, then paid/traded to have it welded together as it progressed. I probably have $200 in material & $100 in welding. I think I paid ~$100 for powdercoating, but I sandblasted it myself.
"Modular Construction" in that APW description means it's screwed together (13 major pieces, to be exact). That's weak. "Gives Your Vehicle A Unique Stunning Look" sounds like they've never sold one. If they have, yours won't be unique. And even if it is, I doubt anyone will be stunned. (I hate advertising hype!) "No-Drill Frame Mount Installation" means it loops under & behind the bumper (VERY weak) to the factory bumper mounts, which are too close together for something that sticks up above the grille. "Limited 3-Year Warranty" probably means they only warrant against rust, and rusty scratches aren't covered. "Image may not be application specific" means they aren't even showing you the one you'll receive. $487.06 means you could build your own sturdy bumper, have it powdercoated, and spend about the same money.
After a few seconds' research, I found:
1) even the GoRhino site doesn't show a pic of it
2) even the GoRhino site doesn't detail the warranty exclusions
3) the frame mount is even weaker than I imagined.
4) I was wrong about the meaning of "No drill installation" - apparently, that means you have to drill 4-6 holes in your bumper to install it
http://www.gorhino.com/productsDetails.aspx?id=357454
http://www.bigcountryauto.com/bcProd...les/3315-i.pdf
The APW extended warranty is an even bigger rip-off than the GoRhino mystery warranty; both in price & exclusions. I wish I could get people to give me money under those terms.
BTW
Don't even think about attaching recovery points to that thing.
BTW
