80 F250 tire question
Old 02-01-2009, 05:38 PM
JMoreland's Avatar
My brother just got an 80 F250 4X4. Just wondering what size tire will fit without any lift. Thanks for the help.
Old 02-03-2009, 12:16 PM
JMoreland's Avatar
Surely someone on here knows this. The only reason I'm asking is I have a set of 285/75 16's but I'm not sure if they will clear on the front. Thanks in advance for the help.
Old 02-03-2009, 04:53 PM
fmf300ex's Avatar
Maybe 33's? Guessing a stock F250 sits around as high as my 150 on a 4 inch lift, and cleared 33's no problem... just normal rubbing at full lock on the radius arm.
Old 02-03-2009, 07:42 PM
Colorado Osprey's Avatar
33" is a 285/75R16
Yes they will fit.
They are a lot wider than the standard 235-85R16's that came form the factory by only about 2 inches. If you have factory 16.5" wheels they are too narrow for 33x12.5 16.5's
I recomend you consider a wider 16" wheel. They could possibly rub, but with a wider wheel and a different offest you can control this.
Long story short.. yes you can get them to fit without any type of lift.
If you want the height without a wider wheel you can get the same height with a 255/85R16, although they are only available in a load range D.
Old 02-04-2009, 10:20 AM
JMoreland's Avatar
Thanks guys. All he has is a Set of the factory 16 inch steel wheels. I already let him take the tires, hopefully they will fit alright.
Quick Reply: 80 F250 tire question
