Resetting Trouble Lights.
Old 05-23-2005, 01:13 AM
68 Suburban's Avatar
What is the procedure for resetting the warning lights on a 87 Ford F-150. Thanks
Old 05-27-2005, 06:37 AM
PKRWUD's Avatar
Which warning lights?
Old 05-27-2005, 08:58 AM
Emissions
Old 05-27-2005, 09:33 PM
PKRWUD's Avatar
Depends on your mileage. If you have less than 75k miles, you can reset it by going to the module under the instrument panel, and with the key off, push a nail or pen in the hole that says RESET, and hold it there. While holding it, turn the key on until the light comes on. After the light has been on for 5 seconds or more, release the nail/pen, and the light will go off in a second or two. Turn the key off, then on again. This time the light should light up for a few seconds, and then shut off. If any part of this doesn't solve it, repeat the procedure.
If your truck has over 75k miles, the module needs to be replaced.
Old 05-28-2005, 05:06 PM
LeClarion's Avatar
Oops.
Last edited by LeClarion; 05-28-2005 at 05:07 PM. Reason: Not sure how i posted this here.
Quick Reply: Resetting Trouble Lights.
