Help 4 wheel drive not working -lights work- vacume to wheels work
I have a 2004 F 150 4x4 supercab STX with 4.6 , 90,000 miles , And I just realized 4 wheel drive is not working - Never had this issue before
When I shift the shifter on the floor the 4x4 light on the dash will come on but I do not hear it shifting under the truck - Thought maybe the problem could be with the vacume lines that go to the front wheels - I pulled tires off and pulled of the vacume lines- When in 2 wd The lines have constant vacume- when I put it in 4 wd the vacume stops on the lines- I can hear the actuater clicking when it does this but stil the 4x4 dosnt engage and I can hear no clunk - I believe that seems to be operating correctly from what O learned in other threads
If I put the GEAR shifter on the steering collum in nuetral and shift the 4x4 shifter on the floor and play around with moving it through 4 w high , low and nuetral sometimnes I can hear it grindin and eventually think I get it to pop in gear but it never does - All lights on dash work fine but I cant get nothing to engage -
Im guessing that if the vacume lines that go to the wheels are working then its not a problem with the actuator -
Any help would be greatly appreciated - I use this truck consistantly for hunting and my 4 wd is a neccisity
%%PLEASE HELP ME%%
%%PLEASE HELP ME%%
on
The following users liked this post:
I tried this when I was checking vacume lines - Had front jacked and put in 4 wd - even put it in gear - I tried to spin the front tires and they would spin freely - Just dont understand, if the vacume is engaging and disengaging at the front wheeles then I would think system should be working - I can hear the actuator clicking but dont get no thudas it makes when 4 wd is engaged -
on
Yes - I just went out and did that (without truck on jacks), when in four wheel drive it will not spin , either in Hi or Lo - but when not in 4 wd it will spin freely - lights all work - the vacume lines are working - I'm thinking it may be a sensor or the automatic locking hubs not engaging -btw - thank you for your help
on
JMC - not rude at all Thank You!! I will do this today - or as soon as I get 2 jacks together - Thank You for ur help!! I think after playing with it yesterday that whweb in 4wd front pass side tire is spinning/got traction but driverside is still goofed - couldn't be absolutly positive cause it was only me, but the mud I was. In showed it was spinning and driversside wasn't - I will do ur suggestion Asap - thanks again
Follow my guide here. It will work for the manual shift 4x4 system also.http://www.f150forum.com/f72/how-dia...m-esof-186872/
If even one front wheel is spinning, your 4x4 is working as intended. You have an open front differential from the factory. That means all the power goes to the wheel with the least traction. If just one of the IWEs fails to lock a half shaft to a wheel, that half shaft will get all the power in the front and neither wheel will spin. BOTH IWEs have to be working properly to get any.pull from the front.
