Home Discussion Forums Photo Gallery Product Directory Technical Articles Recalls & TSB's Product Reviews Classifieds Photo Galleries Ford Truck News Event Calendar Advertise with us
F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain (OEM) > Other Powertrain
Thread Tools Display Modes
Old 08-31-2008, 05:08 PM
Vehicle: 2006 Ford F150
volunteering with Gustav evacuated.. truck out of commission. help asap please!
here is where my power steering fluid is leaking out. i have NO power steering now. everytime i wipe the Boot, it just keeps coming.. bought 2 quarts of fluid but dont know what i need to do to stop the leak. i have been using my truck to haul supplies to all the shelters in my area for the Gustav people. need it back and running asap. please help!http://a684.ac-images.myspacecdn.com/images01/59/l_08064eb0491a700ae662417229b22473.jpg
2006 FX4 1" of lift on 28x4.50 mickey thompsons
2007 Vette C6 - 27mpg on highway!! - stock for now
Old 08-31-2008, 05:14 PM
Vehicle: 2007 Ford F150
tape? replace the boot?
Old 08-31-2008, 05:40 PM
Vehicle: 1997 Ford F150
electrical tape dont work well on the boot, i tried that since i couldnt find duct tape.
also, your leaking power steering fluid out the boot? sounds like you have a bigger issue there that your gonna have to have down time for. ill go look at the book.
04+ uses rack & pinion?
6" fabtech w/ 7" alcan high arc leafs, 4.88 gears with detroit locker, 315/75/16 nitto terra's.
Packin built and blueprinted Lightning powerplant with p&p heads under the hood, backed by a race built 4r70w. what chu got?
[IMG]>>Offensive smiley removed<<[/IMG]Avoid Rods C.A.R.S. 3929 W Clearwater Ave, Kennewick, WA. Rod has screwed with me on a bad transmission build. saga here
Old 08-31-2008, 05:46 PM
JMC JMC is online now
Vehicle: 2000 Ford F-150 4x4
Looks like the Tie Rod end at rack is leaking into the boot. The boot is cut and it is leaking out at that point. Replace seal to stop leak
Regards
Jean Marc Chartier
Old 08-31-2008, 05:48 PM
JMC, i dont think its a easy job to do in the truck. i dont have a 04+ nor do u?
Old 08-31-2008, 06:21 PM
Quote:
I am confused by your post. Please elaborate. I do not own an 04+ but my knowledge is not limited to 97-04 Heritage F-150s. I never told him to do it in the truck I simply posted the cause of the leak and what has to be done to fix it.
Regards
Jean Marc Chartier
Old 08-31-2008, 06:29 PM
so as a temporary fix, i cant just tape the boot? i have that PVC tape that stretches and molds to itself. great stuff. or will it hurt me to drive without power steering for the next 2 days? well, i know it will hurt me, but will it hurt my truck and cause further damage?
Old 08-31-2008, 08:44 PM
sorry to confuse ya, i was trying to think if it was something that could be done in place to cut down time. i didnt know if you had 04+ experience.
Old 08-31-2008, 09:41 PM
Vehicle: 2005 Ford F-150
It can be done in the truck. It is just a regular lip seal that can just be pulled out and replaced. Taping the boot is not going to do anything to stop or slow the leak. Get a small self tapping wood screw and screw it into the face of the seal and it will pop out, then just replace with the new seal. Simple fix can be done in an hour if everything goes somewhat smooth.
2005 F-150 XLT SuperCrew 4x4
K&N CAI, Flowmaster Cat Back
Old 08-31-2008, 10:15 PM
where do i buy a seal? and what is it called?
Old 08-31-2008, 11:35 PM
When I helped a friend change it on his truck we couldn't find a parts store that had one so we went to a local bearing shop and they crossed it to a National or CR and found it on their shelf. Took it back and had it installed in no time. Get the front wheels off of the ground, turn the steering wheel all the way to the left( your pic looks like it's leaking on the right side) remove the outer tie rod from the knuckle, remove the inner tie rod from the rack then turn the steering wheel all the way the opposite way and then you will be able to see and reack the seal easily. Take your self tapping screw and screw it into the face of the seal and it should just pop it out. Then just replace, but be careful because radial lip seals are easy to damage by rolling the lip. Just take your time and make sure everything is clean before you reinstall the seal and you should be good to go.
Old 09-01-2008, 03:51 AM
yeah, me and my buddy looked at it tonight. the gears on the steering motor are all chewed up. gonna go pick a new one up on tuesday (hopefully, depending on the weather) from the Ford dealership and we are gonna put it on ourselves. thanks guys.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
F150Online.com and InternetBrands, Inc. are not affiliated with the Ford Motor Company
