HELP!!! 2003 Ford Lightning Issues
I just got a 2003 Ford Lightning in May of this year and 2 months later I drove it, got gas, went home, and 2 hours later tried to drive somewhere else and it kept shutting off like I wasn't getting fuel pressure. I bought brand new fuel pumps and replaced them, didn't work. Changed the fuel filter, didn't work. Now it's been at the shop for a month and they've replaced the alternator which didn't work. Now I bought a new computer and this STILL isn't the problem! Has anyone had this problem or know what could be wrong?
Most likely the ceramic fuel resistor next to the intercooler pump underneath by the radiator and heat exchanger. Since they are cheap, replace the two fuel relays in in the little box next to the main power distribution center.
You can jump the high/low relay, bypassing the resistor, with a short piece of wire, that should give you full pressure to the pumps at all times. I would not drive it too long in that condition, flooding and causing injectors to leak as well as rich codes could result.
While you are in the main power distribution center, check all of your fuses.
PS On another Lightning forum/s there are pictures and diagrams detailing this operation and problem.
On LR there is a how-to
