Don't worry... it's all "Highway Miles"... opinons?
Old 03-05-2015, 03:06 PM
FordWask's Avatar
Holy crap its been a long time since I was here - but as usual I trust the opinions of my GD friends above all... that's why I'm back.
Im thinking of buying a high miles 08 Expedition Max (250k miles).
It's "highway miles".
What is your opinion of highway miles - does it really matter or is a high miles vehicle ok as long as it's "highway miles"?
Thanks!
Old 03-05-2015, 03:33 PM
Highway miles are ALOT better than stop and go miles. It really depends how it has been maintained. If its had 5k oil changes, transmission fluid changes, rearend fluid changes, coolant etc and they can prove it then i bet chances are it will be good to go.
Only thing i would shy away from is the good ol 5.4 3 valve cam phaser problem with that high of miles.
Old 03-05-2015, 04:22 PM
FordWask's Avatar
Can you elaborate on that?
Or link it up?
Old 03-05-2015, 04:35 PM
glc is offline
5.4 3 valve VCT issues are all over the forum. Look through the V-8 and 04-08 forums.
Old 03-05-2015, 04:50 PM
FordWask's Avatar
Yeah, found the threads. Sounds painful.
Old 03-05-2015, 04:54 PM
azmidget91's Avatar
Sold my 05 5.4 3v with 213,000 miles on the stock phasers..
Old 03-06-2015, 04:42 AM
Need4racin's Avatar
Price needs to reflect it, but a truck with 250-300k miles usually can be bought for a really good deal. Company I worked for has 3v 5.4s with 200-240k with no problems. usually drivers seat wears out before the engine and trans wore out.
Old 03-06-2015, 07:25 AM
burnerr's Avatar
How about an 02 5.4 2 valve with 120,000 well maintained?. JIM
Old 03-06-2015, 08:38 AM
That wouldn't phase me at all if I needed a reliable, lower-priced truck -- especially if you know the maintenance history.
Old 03-06-2015, 10:08 AM
Wookie's Avatar
The only issue I know of on the 2V motors was with the spark plugs and the lack of threads, otherwise they are bulletproof.
Old 03-06-2015, 11:03 AM
burnerr's Avatar
Plugs were changed and no threading problems,went thru the truck when I bought it,trans-axle,rear end,trans.fluid,fuel filter,plugs,plug wires,fuel injection system cleaned,radiator flush and fill,brakes were at 75% all around.This truck hopefully will last me awhile. Jim
Old 03-06-2015, 11:12 AM
burnerr's Avatar
Also swapped out stock air filter for K&N.
Old 03-06-2015, 11:57 AM
glc is offline
I hope you like a dusty intake tube and MAF fouling.
Old 03-06-2015, 01:50 PM
grizzstang's Avatar
I used to work at a car lot and I can tell you that every used car that was sold was "highway miles" and yes they are better miles than city. Unless you can prove 100% they are highway miles assume they are not.
Old 03-06-2015, 04:20 PM
burnerr's Avatar
Dusty intake tube and MAF fouling?,not in 2 plus years.
Quick Reply: Don't worry... it's all "Highway Miles"... opinons?
