Excursion
Excursion--wanders
Old 12-04-2007, 05:17 PM
lil64gto's Avatar
Red face Excursion--wanders
We just installed new ball joints on the left side. new tires, aligned it and it wants to wander all over the road. It feels like it pulls one way and any correction on the steering wheel is to much and than it'll wander the other way. Has anyone ran into this problem with their Ford??
Old 12-06-2007, 12:59 AM
Zaairman's Avatar
Possibly they messed something up in the process... Does it feel like the steering wheel is loose? It could just mean that your steering box needs to be tightened...
Old 12-06-2007, 11:03 AM
lil64gto's Avatar
Question Excursion wanders
We tried to adjust the steering box but it didn't help. We're going to put in a different balljoint in the left upper just tomake sure it's not a defective one. Than i think it's in the gear or pump?
Old 12-17-2007, 12:28 PM
Yankee7985's Avatar
I would first ask why didn't you replace "ALL" the ball joints at once? Did you also check the idler arm for play? They are also prone to wearing out early. I would take it back to the alignment shop and have them check it out again.
Old 01-08-2008, 08:59 PM
70BOSS302's Avatar
I had an Excursion for about a month and got rid of it, I HATED the way it drove. This is coming from a die hard blue oval fan too. Mine wandered all over the road, even worse when towing. Ended up trading it in for an 07 Expedition.
Old 02-15-2008, 01:01 AM
FamilyRide's Avatar
Some wander some, some don't at all. Mines a good one, it's solid as a rock. The ones that do, most are because the steering gear box is "within spec" according to Ford, but needs to be adjusted.
The ones without any rear anti-sway bar tend to feel more loose as you'd expect.
Old 02-15-2008, 01:02 AM
FamilyRide's Avatar
If it started after work was done, trouble shooting should be easy. Look at anything that was changed. But of course you knew that.
Old 05-16-2008, 08:50 PM
dvldog458's Avatar
My 04 Ex did that too....I replaced the stock steering stabilizer and installed a dual setup from Skyjacker. Straight as an arrow.
Old 11-07-2008, 05:03 AM
01 gt f150's Avatar
caster or tow is not set right. you probably notice nore when the road has a crown to it.
does your wheel correct to straight by it's self after you turn a corner? if not its caster.most ford trucks like poss or neg 1 degree tow combined. lower balljoints eff.ect that stuff more than uppers
Old 11-24-2008, 12:32 PM
FamilyRide's Avatar
He probably won't answer since it's been a year since he posted and hasn't been back.
(here's my token Excursion forum post for 2008 )
Old 12-05-2008, 10:16 AM
F-250 FX4's Avatar
Uncle has...2005 Excursion Limited 4X4 with teh V10.....RR Tire flew off. =(
Old 12-05-2008, 10:20 AM
Zaairman's Avatar
And exactly how the hell is that going to help the OP of this thread???
Old 12-21-2008, 06:51 PM
I Eat Hybrids's Avatar
Has anybody tryed putting a sway bar on? My old excursion never came with one. The people over at FTE put hellwig sway bars on their ex's and they cured the sway.
