Help wiring keyless entry system from eBay
I purchased a keyless entry system from eBay and I'm not exactly sure how to wire it. it's different from the Bulldog setup it also doesn't have any kind of model or make name on it just wondering if anybody could help me, attached below is the picture of the install schematics I have a 1997 Ford F150
If anybody could please help me clarify which schematic would work that would be absolutely fantastic I've never wired a keyless entry system before so I'm not exactly sure which one I need to use for my Ford F-150
The 5-wire door lock system.... http://www.the12volt.com/doorlocks/page3.asp#5w
You're system has these relays built in. You'll need to connect the YELLOW and YELLOW/BLACK wires to 12v+.
Then find the PINK/YELLOW AND PICK/LIGHT GREEN wires in the drivers kick panel area. These are lock and unlock. This is where you'll connect the ORANGE and WHITE wires.
Cut the PINK/YELLOW wire and connect the ORANGE to one side and the WHITE to the other.
Cut the PINK/LIGHT GREEN wire and connect the ORANGE/BALCK and WHITE/BLACK in the same manner.
Now these wires do matter which side the go on. You will need to test the PINK wires after you cut them to see which side rests at GROUND. That is the side that gets the ORANGE wires.
It works it works great. now I did break some rules had a really tough time because of the e-brake getting ahold of the wires. so I decided to take the easy way out and wire the system into the passenger door.I patched into cigarette lighter power and ran power over to the door the installation was pretty easy and pretty quick.
