Starting Issue
Starting Issue
I have a 4.2 v6 f150 XLT extended cab with 170,000, no remoteless key entry. I am having an intermittent starting issue. The problem is getting worse.
I can drive the car all day, in and out with no starting problem at all. Then it happens. I get in, all the lights and gauges work, but it won't start. No crank, just silence. I replaced the fuel pump a year ago. Replaced the transmission almost 2 years ago. The battery is good I had it checked today. I removed and checked the starter it worked fine. I replaced the solenoid on the firewall. The truck started just fine. Made 1 stop, truck started fine. Made a 2nd stop at the grocery store, got back in the truck and nothing. No start, no clicking, lights and all are good.
What are my next options?
on
Instead of random parts replacement, how about a step #1
When the key is in the start position, the DTR should pass + VDC to the starter motor relay on the firewall.
The Tan w/ Red stripe wire will have + VDC on it when the key is in the start position and the DTR is aligned to a park or neutral position ( as long as the DTR has not shifted on the trans or the connector corroded ).
Use a known good ground to the meter and to the lug the Tan w/ Red stripe wire is on.
If this is functioning, next is to make sure the Starter motor relay is closing.
- There are 2 large AWG wires on it, one is to the starter, the other to the battery via the fusible links.
Check that the side to the battery has + VDC on it.
If the Normally Open contacts are closing, the other side will also have + VDC on it.
If not, that shows the starter motor relay is bad.
