2000 F150 Headlight problems
Old 06-11-2010, 09:34 PM
bruinsfan27's Avatar
My 2000 F150 is having headlight issues.
First i came out of the super market and my parking/tail lights lights were on even though i had the switch off and my headlights would not come on. I pulled the fuse so the battery would not die.
I thought it had a bad headlight switch so i changed it. Nothing changed still my headlights would not work and my parking/tail lights were stuck on.
So now i changed the multi function switch and my parking/tail lights go on and off with the head light switch but still no head lights.
Once i changed the multi function switch i went to test it by starting the truck up but all the idiot lights lit up on the cluster and my speedodometer had all dashes and the fuse relay is clicking and guess what it wont start.
Any ideas? I need help.
Thanks in advance Bob
Old 06-11-2010, 09:43 PM
SSCULLY's Avatar
Have you had a lot of rain as of late ?
Old 06-12-2010, 12:15 AM
Yes we have but i park in a garage
Old 06-12-2010, 12:17 AM
it is my fuel pump relay that is clicking. Any ideas?
Old 06-12-2010, 07:11 AM
SSCULLY's Avatar
IF the Fuel pump relay is clicking, you can try swapping it with one of the trailer tow adapter relays.
This could be the no start issue, as well as the odometer issue.
The headlamps not working, had to be a different item, if the headlamp switch is in the off position, and your truck has not been in the rain.
double check, but I think the trailer tow adapter battery charge relay is the same size relay.
Old 06-12-2010, 09:12 AM
switched out the relay and no change
Old 06-12-2010, 11:09 AM
SSCULLY's Avatar
When you turn the key to the run position ( no need to try to start ) do BJB ( aka Battery Junction Box , Engine Compartment Fuse Panel ) fuses 23 & 18 have power on both sides ( check with a meter to the pin on the back on both fuses ) ?
Old 06-12-2010, 11:53 AM
Key on 23 yes 18 no. But turn the headlight switch on and 18 does
Old 06-12-2010, 12:30 PM
Could i have damaged some thing in the column? My theft light is blinking along with the relay clicking
Old 06-12-2010, 08:03 PM
SSCULLY's Avatar
Are you sure you are in the BJB ( aka Battery Junction Box , Engine Compartment Fuse Panel ) ?
Fuse #23 & # 18 are powered directly from the PCM power relay, which uses BJB Fuse #2 to power the normally open contacts.
BJB #18 feeds :
- MAFS
- 2 inputs to the PCM
- IAC valve
- The Fuel injectors
- The Fuel pump relay coil ( normally open contacts to power the fuel pump is fuse #10 )
Did you do anything in the column aside from the MFs ?
I guess you could have damaged the PATS transceiver module ?
Best to confirm the fuses above are the correct ones, as if BJB Fuse # 18 does not have power on both sides like BJB #23, there is something very wrong.
Old 06-14-2010, 06:08 AM
Sscully, thank you for the help. I have been pulling the fuses cause my parking/tail lights were staying on. In a rush to test the switch i pulled 18! I dont know why. I must have thought it was a spare and put it 6. What a mess up.
When you said test 18 and 23 i thought you meant dash fuse panel.
Anyway it fires right up with a fuse in there. But still no headlights. Any ideas?
Old 06-14-2010, 06:49 AM
SSCULLY's Avatar
Are the symptoms still the same, parking lamps are always on, headlamps do not work ?
When you pulled BJB Fuse #6, did they go out ?
Old 06-15-2010, 06:33 AM
Yes still parking lights/tail lights are stuck on and no head lights.
When six is pulled they go out.
Old 06-15-2010, 08:18 AM
SSCULLY's Avatar
If you pull that fuse and they go out, I would say the problem is with the main headlamp switch.
Pull and test the main headlamp switch
Pins #11 & #12 seems to be closed all the time, or there is a problem with the wiring behind the dash.
Start with pulling the switch, and install Fuse #6, see if they are on still. If not test the switch.
Quick Reply: 2000 F150 Headlight problems
