Cruise control not working
Old 08-20-2015, 06:06 PM
missileer's Avatar
My cruise on my 2000 Ford F150 is not working either. I ran the self test. It flashed indicating it entered self test. I got a single flash when I pressed "On" but NO flashes when I pressed "Resume", "Coast" and "Set/Accelerate". What does that mean?
Old 10-01-2015, 11:31 AM
rohnerj78's Avatar
What do you do if the light does not come on at all after holding the OFF button and turning the key to the RUN position? Do I have a faulty set of switches on the steering wheel?
Old 10-04-2015, 12:07 PM
SSCULLY's Avatar
This is a test for the 2000 to 2003 ( and 2004 lightning and heritage models ) not for the 2007.
Old 10-04-2015, 12:43 PM
JackandJanet's Avatar
As stated in an earlier post in this thread, have you checked the 3rd brake light? If it's out, the cruise control is disabled in your model year I believe.
- Jack
Old 10-04-2015, 05:43 PM
rohnerj78's Avatar
- Jack
Yep 3rd light was the first check. Come to find out the previous owner used a hypertech programmer to change tire size which deactivated the cruise. My local dealership got it turned back on.
Old 10-13-2015, 05:28 PM
rocketman65's Avatar
2003 F150 Cruise control
I have a new (to me) 2003 F150 and performed the self test on the cruise control. I am receiving - 3 flashes - deactivator switch is open or circuit defective. I have replaced the deactivator switch and through other searches checked voltage on Servo for pin 4 and pin 9. No voltage at all on pin 9. I replaced the brake light switch and not change. So two thing, what does the circuit defective refer to and could it be the servo? All fuses have been checked.
Thanks in advance,
Old 10-13-2015, 08:40 PM
glc is offline
Did you replace the harness when you replaced the deactivator switch? The recall replaced the original harness with one with an inline fuse.
Amazon.com: Motorcraft SW-6350 Brake Repair Kit: Automotive Amazon.com: Motorcraft SW-6350 Brake Repair Kit: Automotive
Old 10-13-2015, 08:50 PM
Yes I did use the new harness. No luck
Old 10-14-2015, 05:22 PM
owkaye's Avatar
Hello all,
I had intermittent problems with my cruise control for 2-3 months before it stopped working completely. Once in a while it would not turn on, and this became more frequent as time passed. Other times it would turn off by itself, sometimes several times within a few minutes. Eventually it stopped turning on altogether.
I just checked fuses 5 and 13 and both are good. Then I ran the self-test:
Press and hold the OFF button while turning ignition switch to run position.
Cruise light flashes once.
Within 1-2 seconds release the OFF button and press the ON button.
Within 1-2 seconds release the OFF button and press the RESUME button.
Cruise light does NOT flash.
Within 1-2 seconds release the RESUME button and press the COAST button.
Within 1-2 seconds release the COAST button and press the SET/ACCEL button.
Since the On and Off switches are together on the left side, and the other three (Resume, Coast and Set/Accel) are together on the right side, do you think my problem is a set of bad switches on the right side ... or in the wiring connections to these switches? Or might something else create this problem?
Old 10-15-2015, 09:50 AM
FordService's Avatar
Ford Customer Service Team
Originally Posted by owkaye
...I had intermittent problems with my cruise control for 2-3 months before it stopped working completely...
Welcome to the forum, owkaye! It sounds like you're going to try to track down the cause of the cruise control issue yourself, but keep in mind you can always swing by your local Ford Dealership for diagnosis. What's your truck's model year/mileage?
Crystal
Old 10-15-2015, 11:44 AM
owkaye's Avatar
what's your truck's model year/mileage?
2003 model year
135,000 miles
Old 10-16-2015, 11:15 AM
02xltscab's Avatar
I'm having Cruise control issues too.
Just replaced the deactivator. Ran the self-test.
Got one flash at the start and a flash after each push of the buttons in sequence. Servo also actuated, but right after the first button press. Not after the last button as described above.
Went out for a test. CRUISE light does not come on when I push "ON" and cruise isn't working.
Stumped.
Old 10-16-2015, 12:23 PM
glc is offline
Did you also replace the harness?
Old 10-16-2015, 12:24 PM
owkaye's Avatar
I think I asked my question in the wrong thread, or in the wrong forum. I don't really know how to interpret my self-test results (other than to think my switches on the right side may be bad) ... so without a definitive response from someone who actually knows, this is the best I can conclude.
Old 10-16-2015, 01:09 PM
02xltscab's Avatar
glc - yes, I replaced the short harness that came with the new deactivator. It went between the main harness (that previously attached to the old deactivator) and the new deactivator.
Note - I didn't mean to highjack this thread. Just seemed good to have the entire group discussion on the same subject all in one thread.
Quick Reply: Cruise control not working
