Powerfold Mirrors
on
A few members on here have added power fold mirrors by adding an aftermarket switch to the mix.
I recall one member that added in power fold, and got them wired to the stock switch, adding the relays after market.
I have yet to figure out if the power fold harness is installed in my Lariat, to be able to plug in the power fold mirror relay, and add the mirrors. If you don't mind doing the wiring yourself between the dash and door, the mirrors can be added.
Adding a power slider, Rock Pick did one in his '01, so going aftermarket or factory can be done, again just how much you like pulling body parts and doign wiring.
Let us know if you are up to it, and we can get started on it.
on
Originally Posted by coverfire
Does the KR have the powerfold mirrors? Because I figured if I am switching out mirrors and all of those things it would be too much more to add puddle lamps. I am curious though, I have never seen one work and I would like to, to see if I really want them or not.
I guess figuring out what you want is the first step. As for taking it to the dealer, I have no idea if they would do it. Installing the pins in the connectors is not a big deal, but adding in the relays or running the wires to the factory location can be a pain as well. I know the Lariat does not have any of the wiring installed to do it 100% factory.
