Has this happen to you? If so, what did you do to fix it?
Old 07-14-2009, 09:21 AM
pmason718's Avatar
Has anyone ever vacuumed there truck out really well but still see like a little bit of dirt that can't be removed using a vacuum? The little dirt that I see is mainly on the driver side b/c I rarely have passengers and I can't see to remove it after vacuuming. I'm using a quality Craftsman wet/dry vac with 5hp. What else can I do?
Old 07-14-2009, 09:23 AM
esf's Avatar
esf
esf is offline
I'm not sure I follow. Where is it at exactly? Why can't you remove it? Does it just require a shampooer type cleaning or is it actually just pieces of dirt that just don't seem to get sucked up in the vacuum? Can you agitate it with a brush to loosen it from the carpet fibers?
Old 07-14-2009, 09:38 AM
fordmaster's Avatar
Maybe its wore down and ground in.
You may have to spot treat with some carpet cleaner. Thats why I have Husky liners throughout my truck. Really cuts down on wear and dirt.
Old 07-14-2009, 10:02 AM
1badstx's Avatar
try brushing it and then vacuuming it
Old 07-14-2009, 10:13 AM
hwm3's Avatar
x2. This should work pretty well for you.
Also, as good as a shop vac is, a vac like the Metro is much, much better at removing dirt from the interior.
Old 07-14-2009, 10:45 AM
All the time... This stuff may be frowned upon, but I just use wither TW or Blue Coral upolstry cleaner with the brush on top. I spray the rugs and srub it, vacumm and then the crap is gone. It's only like $4-$5 for a 22oz spray bottle.
Old 07-14-2009, 01:55 PM
pmason718's Avatar
Meaning that there are pieces of dirt that just don't seem to get sucked up.
Never thought of that
Do you have a link to the Metro vac?
I order some supplies from ADS last Friday which included some interior brushes and I can't wait to get them on Thursday. When I do I will try brushing the carper.
Old 07-14-2009, 02:21 PM
hwm3's Avatar
Old 07-14-2009, 05:26 PM
glc is offline
Folex and a LGM.
Old 07-14-2009, 08:01 PM
esf's Avatar
esf
esf is offline
Originally Posted by glc
Folex and a LGM.
He's not after the discoloration from the dirt or stains but rather the stuff that gets stuck in the fibers that the vacuum just won't pull out. I usually get this around the edges of the carpet where they meet kick panels, the sills, and where the seats mount to the floor.
Old 07-15-2009, 12:50 AM
glc is offline
Understood, but won't it float all that crap out?
Old 07-15-2009, 04:22 AM
esf's Avatar
esf
esf is offline
I guess it would probably work. It's just not ideal.
Old 07-16-2009, 06:37 PM
wiretheboat's Avatar
You could also try blowing with air too. Blows all kind of stuff out and makes cleaning easy.
Quick Reply: Has this happen to you? If so, what did you do to fix it?
