2015 and up water leaks
Would like a single thread where people can note the following:
LOCATION OF LEAK(S):
YEAR:
CAB STYLE:
MODEL:
MILEAGE:
DATE OF MANUFACTURER:
ASSEMBLY PLANT (IF KNOWN):
ANY FIX'S:
You can use this link: https://www.etis.ford.com/vehicleRegSelector.do to determine the date and place of origin
I'm curious how many actual 2015/16's are having issues.
YEAR:
CAB STYLE:
MODEL:
MILEAGE:
ANY FIX'S:
2015 Ford F150 XLT FX4 carpet wet in back. Dealer checked window, third brake lite no leaks. Every time it rained or go through carwash or even hand washed carpet ended up wet. Trucks a year old now with 8700 miles. built Dearborn plant. Finally found it with back panel on back wall removed and a heavy rain a few weeks ago. still waiting for the dealer to get the part in. Yes I found it not the dealer. The VENT leaks. There are 2 big ones and 2 small ones. The 2 big ones are listed as OEM parts, the 2 small ones no one knows anything about, it took dealer 2 weeks and a lot of phone calls to finally get a part number to order. To fix it the bed has to come off to replace the vent and then the carpet is being inspected for mold, if found the all interior has to come out to replace carpet and padding. All of this under warranty of course.
Thanks for the replies everyone!
I had a leak in the back of the cab. Similar to Shicks, except it was not my vents. It was the seaming of the aluminum panels. It was easy to find, the rug would get wet under the passenger side rear seat. The water would run down to the door sill. If you shined a light in between my cab and bed, the the panel about 10" under the window did not have proper seam sealer and it was wavy. If you compared it to driver side, that side was nice and smooth.
Dealer removed my bed, sealed the panel and replaced my entire interior carpet/pad since I had mold. That's how I found the issue. I was cleaning my truck and removed the all weather mat and found mold on the carpet.
Oh, mine was built in February of 2015 in Dearborn
