Sponsored by: DashLynx
door panel removal for speaker installation??
Old 08-17-2009, 11:33 PM
Yo Nadz's Avatar
Question door panel removal for speaker installation??
Anyone taken off the front door panels?? Pics, suggestions?? I am putting in some new speakers tomorrow and dont wanna f stuff up. Thanks in advance!!
Old 08-18-2009, 05:30 AM
Boataddict's Avatar
A bolt in the handle where you pull the door shut, one behind the handle to open and 2 at the bottom. The first two have covers on them you have to pop off. It is pretty easy.
Old 08-18-2009, 07:22 AM
kingfish51's Avatar
The problem is getting everything lined back up to get the panel back on, especially the door lock.
Old 08-18-2009, 07:52 AM
F150Aggie's Avatar
https://www.f150online.com/forums/20...r-upgrade.html
I suggest you try to keep everything in one thread , it doesn't make any sense to make multiple threads about the same topic.
Old 08-18-2009, 08:04 AM
ibcop's Avatar
Door panel removal/installation is a piece of cake. Once you have the bolts removed, make sure you pull straight up until all the "fingers" clear the door.
And oh, be careful while prying the cover off that is behind the door panel - they mar easily - just use a small straight edged screwdriver.
Once the door panel is off, hold it in one hand and reach behind with the other and you'll see two clips that you can push in to release the door handle. Once released, it will slide back through the door panel. Some people release the cable, but it's not necessary.
You'll see the wires that need to be disconnected to get the door panel loose. If I remember, I believe the door speaker bolts are 5.5mm, but a 7/32" will work as well. Just take your time.
Did you get the speaker adaptors so you don't cut your factory wiring?
Good luck!
Old 08-19-2009, 04:40 PM
Yo Nadz's Avatar
Awesome. Thanks guys. Im gonna try it now. Ill let you know if I run into any problems.
Old 08-20-2009, 12:38 PM
todd01's Avatar
door panels
i use a straw attached to the door lock to put panel back onto door.
Old 08-20-2009, 12:42 PM
ibcop's Avatar
Now that's thinkin'! Thanks for the info!
Quick Reply: door panel removal for speaker installation??
