Sponsored by: DashLynx
Popping / Creaking Noises in Rear End of 2009 KR
Old 11-27-2009, 12:32 AM
troyf150's Avatar
I'm having loud popping and creaking noises in the rear end of my 2009 supercrew king ranch. I took it to the dealer and they oiled / cleaned the rear leaf spring. They said there was a technical service bulletin on this, but that nothing was wrong. After one day the noise has returned and is very annoying. My 2001 supercrew never had this problem in 105,000 miles. Anyone else know of this problem?
Old 11-27-2009, 01:00 AM
broncobran68's Avatar
Is it the 6.5' box? Seems like there is a driveshaft issue with a tsb coming soon.
Old 11-27-2009, 10:54 AM
troyf150's Avatar
No I have standard 5.5 ft short box and standard rear end diff (none locking).
Old 11-27-2009, 11:02 AM
Take it back to the dealer.
Old 11-29-2009, 12:44 PM
troyf150's Avatar
I already did that. They told me it was normal. I guess I will take it to another dealer.
Old 11-29-2009, 12:53 PM
Where are you located and what dealer have you been taking it to? I'm sure some would like to know what dealer to avoid. My dealer (Bankston Ford in Burleson) always takes good care of me.
Old 11-29-2009, 08:22 PM
steelcitykid's Avatar
Thumbs up
I had the same popping noise with my 09 screw. Took it in and they said they had tsb about dirt in the leaf springs. I was like yea right, I figured I would have to bring it back cause that could not be the cause. lol
Well it has been good ever since. I would like to see the tsb, but when I picked up the truck I was in a hurry.
Just take it to another dealer and tell them to do that tsb and you will be good.
Old 12-03-2009, 07:29 AM
troyf150's Avatar
Jennings Anderson Ford in Boerne, TX is the dealer I took the 09 screw to. They said there was a tsb about dirt in the leaf springs. I could not find it listed on alldata. They cleaned / oiled the leaf spring and it was good for only one day.
Old 12-07-2009, 08:53 AM
I took mine to Sam Packs in Carrollton, Tx. I have to go back for another issue soon. So I will ask about what they did, it has not returned since.
Old 01-16-2010, 02:45 PM
troyf150's Avatar
702200 - nvh noise concern -- rear
Special service messages
20881 2009 f-150 may exhibit a creak/squeak type of noise from the rear suspension. Some 2009 f-150 vehicles may experience a creak/squeak type of noise from the rear suspension. If this is encountered then inspect both rear leaf springs front and rear clinch clips for clearance to spring. Verify there is a 3/32 - 5/32 of an inch (1.0 - 1.5 mm) side-to-side clearance between clinch clip and spring. If hard contact exists, then open clinch clip using an adjustable pliers. Wrap electrical tape on the jaws to avoid damaging clinch clip isolators and/or coating. Place adjustable pliers on the top end of the clinch clip and slightly bend outwards to obtain 3/32 - 5/32 of an inch (1.0 - 1.5 mm) side-to-side clearance. Be careful not to damage clinch clip. Do not apply lubricant to clinch clip isolators.
Effective date: 07/10/2009
Old 01-26-2010, 04:10 PM
troyf150's Avatar
Took the KR back to Jennings Anderson Ford. They replaced the rear leaf springs. Said there was excessive clearance. Hopefully this solves the noise issue for good.
Old 01-27-2010, 07:59 PM
troyf150's Avatar
OK - with new rear leaf springs the creaking noises are gone! Don't know if anyone is still reading this post, but if things change I'll let you know. Hopefully, this is it and the problem is solved for good. For reference, I have 6,000 miles on the 2009 KR now.
Old 02-01-2010, 12:12 PM
Brian M's Avatar
Had this done last week and it worked.
Old 09-15-2010, 03:50 PM
rootem's Avatar
My 2010 F150 SCREW with 7000kms was in the shop yesterday for the 3rd time for this problem. First time they lubed the rear springs and shakles squeak went away for a day. Second time the replaced the rear leaf springs and hardware. Noise came back shortly afterward. In the shop yesterday they disassembled and lubed rear leafs again. I made sure to jump on the back of the truck to see if the noise was still there. It was even worsr than before so I got the sales and service manager to come out and have a look. They are stumped to what the problem is. Unfortunate part is we do not have lemon law in Canada. Don't know what to do now? Any suggestions?
Quick Reply: Popping / Creaking Noises in Rear End of 2009 KR
