Anybody Ever Replace their Rack and Pinion?
Help Please:
Its come down to me needing to replace my rack and pinion on my truck. Its producing a clucking within the rack indicating that it is shot, as well as my tires taking a bit of wear on the edges.
so my question is has anyone tackled this project on their own? what were your experiences?
Thank you to all that throw in their tid bits. i dearly appreciate help in this 2 year issue ive had
well i was thinking that too but i feel that since i just replaced those (around a year ago) they wouldnt be at fault ALREADY!...
but the noise sounds like its definately inside the rack ... almost at the point the steering shaft goes into the rack.
But im thinking that sparing any special tools... i should be able to tackle this project ... after lots of digging....
We would love to talk to you about this matter. If you could call our Technical Director , Joseph End, at 215-912-3245 that would be greatly appreciated. We look forward to hearing from you.
Thanks,
Phil Curry
bummer
I replaced the shaft already to only a little LESSER of what I was experiencing but it is well and alive still...
Turning into driveways .... Articulation causes the shift and the knock ...
Parked rocking wheel back and forth... It's there
Grabbing the shaft in the engine bay ... It's there
https://www.youtube.com/watch?v=SApiCOwT9p0
^^^^ this is the noise ... Which sounds like this while driving too and drives me nuts
How can I be the only one!?
My email is pcurry@cardone.com If you email me your number, I'll have someone call you.
Have been in talks with a rep for A1 Cardone ... Recommended I get some information on a TSB regarding a low pressure power steering line that may cause the knock. Cannot be the issue IMO because the truck does this while OFF even
I know the problem is within the rack.
I've sent him a link to my YouTube video of the problem. Will remain updating until a solution is found.
