2007 4.6 blown out plug!! still in cylinder?
Driving through Knoxville last night. Loud popping under hood. Stopped popped hood felt leak from passenger side coil pack #3 I think. Coil is still intact and secured. I've heard of the plugs ejecting from the aluminum heads. But my plug is still in the cylinder. Could it just be loose? Maybe threads are still in tact? 500 miles from home. Should I have it towed to shop to try to not damage threads any more? I was only going about 10 mph when it blew. And pulled into a hotel right away? Any idea of repair costs best and worst case scenarios. Thanks guys
Blown out plugs were only a real issue on 1997 - 2001 trucks as I recall where they had just 3 threads holding them in. It didn't take much to over torque them and damage the threads - leading to a blow out. So that would mean your truck has the redesigned heads with more threads holding the plugs in place. This would also make blowing a plug out pretty unusual. Have the plugs been changed recently by any chance?
Getting back to the problem at hand, without looking down the plug bore to see what's still there - and looking down into the cylinder bore with a borescope to see what's going on inside - it's tough to say how much damage you've got. One thing I can say is that if anything got down into the cylinder bore itself, the damage happens almost instantly. Even pulling off and shutting down as fast as you did wouldn't help if something got down in there.
Let's hope for the best scenario where something (maybe the porcelain) blew out and all you have is a busted plug and a compression leak due to what's missing. That would be much easier and cheaper to fix.
Let's just hope you blew out the porcelain and all it takes is pulling what's left of the old plug out and threading a new one in. Make sure to check the threads very carefully.
As for a Helicoil, they actually work pretty well when installed correctly. Did somebody change the plugs recently? Just wondering about the root cause.
