Transmission FLuid Change
Ok, I've searched and cannot find any definitive answers on this. How often or when should I have my Transmission Fluid Changed? I was at the dealership today and they asked when i last had it done. I told them I hadn't - I am driving a 2006 that I got in August of 2008. I got it with 40,000 miles on it, and it now has 49,000 miles on it. The dealership told me I should have it done and that it was due at 30,000. I do not think it was done by the previous owner. I put about 4,500 miles on it each year under normal driving conditions - it is babied... Any advice would be appreciated on whether this should be done soon, or if I can or should hold off.
Thanks,
Steve
Thanks,
Steve
My rule of thumb no matter what "brand" of vehicle is if you tow or work the truck hard, The trans should be done about every 35K. If it is a daily driver and just a daily driver, every 50-60K.
No matter what you drive, small amounts of clutch materials wears and collects in opening. This can have an effect on internal pressures which of course relates to shifting.
Service your trans but inspect the fluids you remove for excessive clutch material or worse, metal...... Take care of your vehicle and it will provide you with years of service.
To the OP - get it done, you don't know how the original owner treated it.
RTFM..... 30K under normal driving is for the Torqshift transmission (which are not in F150's), 30K is for vehicles that are driven under "Special Operating Conditions". 150K is what Ford recommends for normal driving. So, don't take it from the guys who aer gonna tell you one thing or another. See what Ford engineer's put together for you.
I changed mine at 96K after 4 years of hauling, towing and plowing. I only changed it because I occasionally have odd shifting. I did the old fashion pan drop for fluid and filter. And sent the fluid to Blackstone Labs for evaluation. The only negative was they found a little bit of oxidation and insolubles. (the cause for this was a failed fan clutch while plowing, trans fluid was up to 235) They commented that they saw wear characteristics similar to that of a trans with 26K on it.
Change it if you want for a little peice of mind, but I doubt it's necessary. Oh ya, your Ford service guy is going to recommend that you do this or that, it's not in your best interest. Part of his income is based on the services he sells.
Are you guys talking about a full flush, or just draining and topping off??
Anyone heard guys saying that they've had more issues after a flush?? Something about making it wear differently, thus accelerating wear/issues?? Sounds crazy, but I know I've read it more than a few times..
From reading here and other Ford Truck sites, flushing is typically fine, if your transmission has NOT started to act funny. Once they start acting up a flush seems to speed up the failure.
I'm not sure that I buy into that concept. I think those transmissions that were acting up were getting ready to fail, regardless of the flush.
A FLUSH will remove clutch material deposits that build up here and there. A DRAIN will only remove the fluid. Regular maintenance will reduce these clutch material and other build-ups. If a trans is left for 100K miles and then flushed, it could lead to disaster. By this time, there are lots of build-ups and internal line pressures have changed but the FLUSH will immediately return these back to almost original by removing the deposits. Now, this is when a most weak trans will start to fail....
The old saying is if you have not done regular service, "let the sleeping dog lay" and leave it alone.
