P0191 Code Help
Old 12-16-2008, 10:56 PM
kens fx4's Avatar
P0191 Code Help
I've searched the threads on this one and found a few, but none with any final solutions to it..
the P0191 code came on the other day
truck it running good and still strong!
i checked with the edge and got the FRP at 75 constant
so i'd quess the fpr sensor has gone bad...
BUT i also got on the edge (only) a p1237 fuel pump primariy circut malfunction.
Is there something else here .. TWO fuel pumps or a back-up circut?
any info would help..
thanks
Ken
Old 12-18-2008, 04:32 PM
kens fx4's Avatar
ANYONE?
i don't have the money to just start guessing and buying parts.
Has anyone had this code? and how did you get it fixed.
Old 12-19-2008, 06:26 AM
2stroked's Avatar
Found the exact same code stored in mine last week. It's related to Fuel Rail Pressure - either high or low. It can also be the fuel pressure sensor going bad. I'm going to start by replacing my fuel filter because that could cause low fuel pressure if it's partially plugged. After that? We'll just wait and see. By the way, other than a hiccup one day on the way to work, it runs just fine.
Old 12-19-2008, 08:50 AM
FX4effects's Avatar
I have had the code before but I had another issue also. The truck would buck and surge above 2500 RPM like it wasnt getting enough fuel. I changed the filter, that didnt help. I thought I had a bad tank of fuel but it still did it with new fuel. I thought I was going to have to change the fuel pump however, then I put in Sea foam (injection cleaner), that fixed the entire problem and never had the code again. filter $13 Sea Foam $8 me happy priceless.
Old 12-20-2008, 01:11 PM
kens fx4's Avatar
Thanks!
I know the filter is good..
so i'll try some sea foam to see if that works..
How long after you put in the sea foam did it take for the code to go away?
Ken
Old 12-20-2008, 01:47 PM
FX4effects's Avatar
I cleared the code with my superchip just after I put the seafoam in and it never came back. After I put the seafoam in it took most of the 1/2 tank of fuel for the surging problem to go away. You can also clear the code by unplugging the battery for a few minutes. If the code comes right back you may have other issues???
Old 10-14-2009, 03:55 PM
Troutbuggy's Avatar
Hey Ken, How did this work out for you? I'm throwing the same codes and hesitating...
Old 10-14-2009, 07:02 PM
bjp207's Avatar
Filter solved it for me
Old 10-29-2009, 11:52 AM
Troutbuggy's Avatar
Update on my issue, Used Seafoam and replaced the fuel filter (needed both), but issue remained. Gave in and took it to the stealership and they found a bad fuel pressure sensor and replaced it. After diagnosis and parts and labor and tax and coffee and tea, it totalled $470. Problem solved though and I do fart much quieter now...
I'll check that part # and post it up this afternoon.
Old 10-29-2009, 01:34 PM
Troutbuggy's Avatar
From the notes on the work order:
"Found fuel pump driver module corroded and broken"
Part # 4L3Z-9D370-A
Description: "CONTROL ZOO"
Price: $148.95 (CDN)
(Taska price = $69.48)
Quick Reply: P0191 Code Help
