2007 F-150 and Hardwire Radar Detector
I've done a search on this, but I've come up empty.
Here is what I want to do. I have a 2007 F150 SUpercrew 4x4 Lariet.
I want to mount my Bel Radar Detector in the headliner adjacent to the rearview mirror, run the power wire in the headliner, down the A-pillar to the fuse box on the passenger side. The radar detector has an inline 1 amp fuse.
I want the radar detector to only be on when the engine is running or the key is in the accessory position.
When I had my 2002, I tapped into a black wire with red stripe under the steering column and it worked great.
I went and bought one of those "Add a fuse" kits from Autozone for $5.00.
My question is: What fuse # do I tap into in the fuse block? Or should I did like I did in my 2002 and tap into the steering column? Does this black wire with red stripe still exist under there??
I have a sunroof and don't want to tap into the switches up there. Down the A-pillar seems to be cleaner.
Thanks for your help in advance.
Rob
Rob
This is the exact setup that I have done with my radar detector. I bought a 12V cigarette lighter from walmart so that i didnt have to cut the wire for the radar detector. I dropped the wires down the passenger A pillar and tucked the cigarette lighter above the headliner above the passenger sunvisor. Next to the fuse box is a green headed sheet metal screw that is a ground and i tapped into a wire running out of the fuse box that is a switched source. You can see in the picture below that the switched power wire appears to be blue.
and i have the detector mounted to the left of the rearview mirror so that it is easily accessible for the mute button and up off the dash and out of sight of would be smash-n-grabbers.
hope this helps.
ox
hope this helps.
ox
Rob
Rob
https://www.f150online.com/forums/sh...d.php?t=269523
Update- Completed Install
Just an update....
I followed Oxlander's instructions and everything worked out great. Here are a couple of pictures similar to what he had posted.
Keyed Power Source is the blue wire with green stripe....
Ground connection.....
If anyone has any questions, let me know....
Rob
Rob
With lidar (laser) becoming more and more popular, do radar detectors do anything but let you know to pull over and get your ticket? I drove with one a few years ago and it seemed to give me a false confidence to go fast. I used it for a couple of months and then gave it back to my buddy.
Originally Posted by dmelchi2000
The one that i have is a scrambler for all forms of radar and laser. The company will pay for any ticket you get within the first year. It is made by Rocky Mountain Radar company.
Have you read the fine print on their ticket policy?
Originally Posted by Impact9
you all do stuff too hard. You know that lights up there just above your detectors are 12 volts.
I tapped my wires right there. Took like a whole 2 minutes.
Originally Posted by Oxlander
Yes, I knew they were there but decided not to use them because they are not switched. They are constant hot and it would be just my luck that I leave town on an extended trip and forget to turn off the detector and return to a drained battery. The way I installed it, the detector is set to turn on and off with the turn of the ignition. Nothing to remember (or forget) and always at the ready.
For my Valentine 1 radar detector I tapped into the power rear window wiring in the overhead console. It's switched so when I turn off the ignition and open a door the detector turns off. Start the truck and it's on.
On trucks that don't have the power rear window it may be worth a look inside the console to see if the wiring is there anyway. Just grab the console and pull straight down (it's held on by clips) to check it out.
I then ran the cord (which is like a flat telephone cord with modular plugs at each end) for the remote display from the detector under the front edge of the headliner and down behind the A-pillar trim and under the dash. I mounted the remote display on top of the cover for the steering column just ahead of the guages.
