Question about keyless entry
here you go..(for the keypad)
https://www.f150online.com/forums/sh...ess+entry+code
a new key (since you only have one) could cost you around $100 -for the key, and having it programmed to your truck... the remotes shouldn't be that expensive, but again, they need to be programmed to the truck
Originally Posted by benkr16
but by the way, i only got one key with remote....any ideas on how much a new key and remote might cost?
If you have owners manual, read the procedure on programming the keys. They are indeed special and when you have two keys you can program additional keys, but with only one a dealer must do it. Usually the keys are available on ebay and sometimes the remotes, but wherever you get them you will need to go to the dealer.
Ok, so if its gonna cost over a hundered dollars for all that codded keys, and remotes and programming crap from ford. Would it be better to get on of those alarm/remote entry/remote start kits that i see for like 150? Would that cause a system proplem with the current stock alarm on the truck?
