Mounting FX4 Fender Flares on XLT
not sure if this is a dumb question.... but what is the best, and easiest way to mount these fenders on my truck? I have an 06 SCrew.... and got some
FX4 flares on EBAY..... they have clips on the inside (fender side). do i need to drill the fenders or can i mount them with out drilling the fenders?
If you search around you'll find a few different answers. You can either drill out the holes to use the original clips or you can use some 3M tape in place of the clips. I've read that drilling the fenders is a long tedious process, make templates, check the alignment, recheck, walk away, check again, then drill away. I've got an XLT and have been wanting to do this for awhile, just never found a reasonably priced set. If I do find a set I was going to go the 3M tape way and see how that works out before drilling. One concern I have about it all is getting dirt/salt between the flare and the fender and creating a corrosion issue.
Definitely post back how it goes for you. Good luck!
I mounted Lariat flairs on my XLT using FX4 flairs as templates.
Since I work in a tool shop, I used one of the mounting clips to
make a “drill jig”. Using the clip, I drilled a small hole thru the
flair at each mounting location. I then put blue painters tape on
the body panel and carefully located the flair before “spot drilling”
thru each small hole in the flair. I then removed the template flair
and proceeded to drill the holes in the sheet metal (very scary at first).
I then painted the raw edges of the sheet metal before mounting
the flair. I don’t know if this was the best way to do this or not, but
since I was going to drill all these holes in perfectly good sheet metal,
I didn’t want to screw it up. I now have a set of FX4 flairs with holes
in them, but I think the end result was worth it.
It is quick and easy. I added the FX4 flares on my 04 XLT Screw. Pull off all the clips and throw them away. Just drill holes on the underside of the wheel well and use stainless scews/washers to fasten the flares on (not on the outside surface where the clips would have been). Use the holes in the flares as a template to drill the holes. When tightening the screws, push the flare against the outside surface of the fender nice and tight. It would be hard to fit a razor blade between the flare and the fender when its done. I have had mine on for over a year and no noise or vibration or loosening at all. Good luck.
ideas...
GChuff & Fuzzola,
do you guys have any pics of the install?
does anyone have pics of fx4 or lariat fenders with the flares taken off?? i would not mind drilling if i can get a visual of the finished product (fender w/ holes).... the rears appear to be fairly easy as they attached to two existing bolts that hold a support bar for the rear fender.
Another bit of advise....I put several small strips of painters masking tape on the fenders where the top edge of the flare meets the fender.The tape kept me from scratching the paint during the trial fitting and drilling process.By the time you're done trial fitting and drilling you will have pushed the flare firmly against the fender several times and you may need to remove and reinstall the flare a few times before you're done.If you're not careful you can scratch the paint.After all of the holes were drilled I removed the tape and did the final install.
