Wet Floor
Wet Floor
I have a 2002 and have recently noticed that the rear passenger floor board is often damp. I've since removed the mat to help dry it out a little more. I'm tired of having to air out the mildew smell for a couple hours so it's not so overwhelming. Anyone have any ideas where it may be coming from and/or how I can go about fixing it?
It's probably not the third brake light on a 97-03 body style. Mine leaks when it rains good so I checked the brake light. There is no way it was leaking there. The issue with our body style seems to be the seal around the rear window.
Check out the How to articles and there is a write up to fix this.
I still need to do mine........but it's spring time in Calif. so it probably won't rain for another 6 months.
Good luck
Good luck
First off welcome to the forum =) Hope we can be of some assistance to you
Do you have a sunroof?
If so maybe the drains are clogged up there
Or sometimes something as simple as a door weatherstripping is bad
Do you park on a hill that would encourage the water to go down towards the passenger side? Or are you on level ground .... that could hint at which side of the vehicle it is happening on
Good luck
Good luck
Both those numbers are guesses, you can make some calls to get a better quote.
There is a how to in the articles for re-sealing the rear window. DIY I don't think it would cost more than $30, but that is a guess. I have heard somewhere in the $125 neighborhood to have a glass shop do it.
