Rear Disk Parking Brake Adjustment
What year truck?
I have seen some that you can adjust like a regular brake drum. See if there is a rubber plug that you can pull off the front of the rotor, if there is there is probably a start whel in there you can adjust. Some vehicles a nut and threaded rod type setup on the cable itself underneath the vehicle.
-Jon
-Jon
