2WD tires?
2WD tires?
I know that the topic of tire sizes has been discussed on dozens of threads, but I cannot seem to get a firm answer for the question:What is the maximum tire size for stock rims (16x7?), no lift, '98 supercab?
Can I run 275-70-16? I had this size Michelin LTX m/s on my '97 4x4 Expy and swore I would not run anything else. Will they work on 2WD or do I have to go down to 265?
According to tirerack.com, the recommended rim width for those tires (in both 275 & 265 widths) is 8". The rim width RANGE listed is from 7" - 10" (275) or 7" - 8.5" (265).
You could probably shoehorn them on your rims, but I would imagine that you might see funky wear patterns, or experience strange driveability problems.
Here's the link:
http://www.tirerack.com/tires/Spec.j...odel=LTX+M%2FS
Good luck!
Here's the link:
Good luck!
