will lightning wheels fit
Old Aug 9, 2002 | 12:48 AM
nace19's Avatar
will OEM 2002 lightning wheels fit my 97 f150 XL?
Old Aug 9, 2002 | 07:21 PM
01screw's Avatar
No they will not fit, different lug bolt size 12mm and 14mm.
Old Aug 9, 2002 | 07:27 PM
nace19's Avatar
i almost bought them to.thanks for the info
so will any lightning wheels fit?how about the 99 or 00 ones?or are all f150's 99 and up have 12mm lugs
Old Aug 9, 2002 | 07:29 PM
nace19's Avatar
hey wait i could have sworn u just said they would not fit
Old Aug 9, 2002 | 07:36 PM
01screw's Avatar
nace19,
I looked up the wrong vechicle. I rechecked and they will NOT fit! The lug bolts are definately different sizes. Sorry for the confusion.
You need to find wheels from a 1997-99 (prior to Nov. 1999 production) to fit your truck.
Old Aug 9, 2002 | 07:41 PM
sagittarius's Avatar
YES, Mid 2000 assembly year, the lugs were changed from 12mm to 14mm. The center hub stayed the same. You can put a 2002 on a 1997, but not a 1997 on a 2002. The weight and centering is done by the hub, not the bolts. Don't know when the Ligntnings switched, but they will fit your 97.
Old Aug 9, 2002 | 07:48 PM
01screw's Avatar
Not recommended as you will have some "play" from the larger lug holes.
nace19,
e-mail me if you want and I'll give you a link to another forum where someone who tried it firsthand and is having problems with "play"
Old Aug 10, 2002 | 09:21 AM
2000regcab54's Avatar
THEY WILL FIT!!!
Here they are are my 2000 with the 12mm studs. These are the wheels off of my brother's Lightning with 14mm studs. These wheels are hubcentric which means the wheel centers on the hub, not the lugs.
Old Aug 24, 2002 | 10:58 AM
s.haun's Avatar
These have worked on my 1998 for about 18 months...
Old Aug 24, 2002 | 01:46 PM
PhillipSVT's Avatar
They are working on my 99 and I have the 02's on it. Just got the acorn style lug nuts and everything fits great.
Old May 31, 2020 | 11:24 PM
Matador28MR's Avatar
Yes they fit On my 2003 Ford F-150 supercab
They fit, I put 18x9.5 lowered on beltech 4in the back 3 in the front. Their is a bolt in the front that is connected to the lower control arm that I removed, so now I hardly scrape when i turn all the way! The back tires are 265/65/18 and the front are 285/50/18 on my 2003 Ford F-150 supe
Old May 31, 2020 | 11:43 PM
Of course 2002 wheels will fit on a 2003, they are both 14mm. This thread was asking about 2002 wheels on a 1997, and the thread is EIGHTEEN YEARS old.
Old Jun 6, 2020 | 12:05 AM
Veteran: Army
the steering stops are different though, so pay attention to the lessons learned in 1999 and install the Lightning steering stops with Lightning wheels
Old Jul 29, 2021 | 11:03 PM
9193darrell's Avatar
I have a 2000 F150 that I am wanting to some of the Lightning replicas that LMR has. Trying to make the best decision and I am still a little lost on the back spacing issues. Any advice as I see you have the similar style that I am interested in?
